28/8/10 Dear Sir/Madam, I have a Dreamland Model PD5A double electric blanket, with dual controls, model 972A1. I cannot recall where or when we bought it - but it was years ago. One half has ceased to function: i.e. the indicator light flashes intermittently, and the blanket never heats up. I have tried adjusting the control to "off" for a few seconds, as recommended in the Instruction, but this has no effect. Can the problem be corrected by replacing the control unit? Chris Penny email address: den2arius@msn.com
  • den2arius Aug 28, 2010
    Yes. Your answer confirmed my suspicions. Thanks for your comments.
  • 2,272 Answers
YES replacing the control will help.The other possibility is faulty burned out heating element.But flashing light is indication of faulty control unit.if the light is operating then there will be a fault in either the blanket or control. --------------- The indicator light on blanket is flashing as soon as the blanket is turned on:--- This is indicating that the control unit is now faulty due to the blankets heating element safety sensor activating because it has detected overheating or the blanket being allowed to ruck or a crease.
All Dreamland Ready for Bed blankets are protected from overheating by Sleep Guardian Technology which will shut off the blanket before it becomes unsafe to use.
The most common reason for the overheat sensor activating is when the blanket is operated at a pre heat setting, whilst the user is in bed, this causes localised overheating causing damage to the blankets overheat system*, the advance technology of the control unit will pick up any fault within the blanket and shut down and eventually fail altogether, the time out indicator will then start to flash.
Once the control is faulty it will not work on any blanket, also fitting a control to the blanket or half of blanket that has caused the fault will result in that control picking up the same fault and eventually failing. This may not be straight away as it will depend on the damage that has been caused to the heating element sensor system.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Aug 28, 2010
Left message with co. No answer back. Called store where I bought blanket-said they had no information about a recall.
The recall electric blankets were sold under the model names Controlled Comfort, EH 2000, Starbright, Staywarm, Supreme 21, Warm Comfort, and had serial numbers A001A ... For more information, consumers should call Biddeford Textile Corp. toll-free at (800) 789-6441 anytime, or visit their web site at www.blanketrecall.com.
Mar 14, 2018 | Home
Dreamland electric double blanket suddenly stopped working after making bed in the morning.
Yep..the element, or wire inside the blanket is probley broken, or touching just enough to work sometimes. No easy fix for this..and it would be dangorous to do it anyway..
Dec 29, 2014 | Home
HOW DO I GET MUCH MORE HEAT, WHEN GETTING VERY LITTLE HEAT FROM DREAMLAND DOUBLE ELECTRIC OVERBLANKET WITH DUAL CONTROLS.
Dual controls implies that the blanket has two separate heating circuits. Do you experience the same problem on each side? If not, you may have a faulty thermostat. If so, it may be a faulty controller or power supply issue.
Dec 29, 2014 | Refrigerators
Need replacement controler 972a1 for blanket bf4a
Everyone who has one of these blankets needs a new controller - join the queue!! The maker is Imetec, you may have someluck with their Customer Services; the controllers sometimes pop up on that auction site at around the 20 quid mark.
Nov 11, 2014 | Heating & Cooling
I need electric cord for Winter's Tale Blanket-Q Model#0906P04CN -Q
I too amlooking for where I can get a remote for a Blanket K 0906P04CNk
Feb 20, 2014 | Winter's Tale Microplush Electric Blanket...
Dreamland electric blanket model 972A1 dual control, one of the control lights flashes but there is no heat
Hi and thank you for using fixya:
Please check the little fuse. and also check if the resistance is getting red hot?
thanks
Oct 25, 2010 | Health & Beauty
My light flashes twice, then stops, then repeats.
http://home.btconnect.com/ledaproducts/page10.html had the same problem myself, looks like its knackered
Feb 01, 2010 | Kitchen Appliances - Others
The control unit does not work IMETEC MODEL 972A1
To: b_t_burgess8
Subject:
The control unit does not work IMETEC MODEL 972A1 can you supply a new one
Date: Oct 28, 2009
Telephone Imetec (UK) Ltd:
Direct Line to their Customer Service Department: 01-606-837-751
Imetec (UK) Ltd are currently out of stock of the
IMETEC MODEL 972A1 controllers but expect a delivery next week (early November 2009).
Their cost for a new IMETEC MODEL 972A1 controller is £20.50 including VAT, Packing & Posting to UK destinations. They accept payment by credit card.
Imetec (UK) Ltd’s website not much help:
http://www.imetec.it/catalog.worldsupport.country.aspx?&provinceCode=XA&regionID=4
For other Imetec (UK) Ltd telephone numbers see:
http://www.uk-local-search.co.uk/details.aspx?id=815841
Hope this is helpful.
Oct 13, 2009 | Kitchen Appliances - Others
Dreamland electric blanket not heating
Yes we had an electric duvet from this company and it stopped working. Was replaced very kindly and no fuss by John Lewis and the same thing happened. (They had said they wouldn't replace again) . Spoke to the company but the woman was very rude. Said that if we lived in a rural area that was our tough luck basically. (A power surge or something). I don't think that's acceptable but we have given up on it now. I think there are 'known' issues with these products that are beingswept under the carpet.
Dec 17, 2008 | Heating & Cooling
Heating & Cooling Logo
482 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
