Question about Dualit 20247 2-Slice Toaster
My dualit toaster heats up but the element doesnt go red do i need a new element
  • 1,711 Answers
Yes only the ones that not getting red, there are in ebay, very good price and they wll arive to you in days.
You can find istruction how to order and how to replace in this tip
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Posted on Sep 01, 2010
Dualit Toaster on light blinks
Most of the time it is indicating something is wrong. What? could be a thermostat, an overheating sensor, bad cabling inside, or just the element.
Mar 10, 2015 | Dualit Kitchen Appliances - Others
Out Dualit toaster keeps blowing the fuse. It's
Probably one wire Loosen up or a wire from one heating element have cut off and is contacting the metal body of the toaster. You need a good visual insect of your toaster, you may use a flush light to see inside the electriacl elents and also open the bottom base to insect the wire conections to the heating element.
I beleive one or more heating elements is the problem and you need to replace them.
Good Luck
Feb 01, 2010 | Dualit CTS4E 4-Slice Toaster
One side of my dualit 4 slot toaster is not working can you help?
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the six in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Jan 19, 2010 | Dualit CBF4M Stainless Steel Buffet...
The center panel of my 2 slice Dualit toaster is not heating. Can I replace it?
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Jan 06, 2010 | Dualit Vario 2 Slices Toaster
Inherited a Dualit Vario 3 Toaster without instructions
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Good Luck
Nov 12, 2009 | Dualit 31210 3-Slice Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
Dualit 2 slice toaster
The top red button is the heating element selector.
If you push it to the left, only the left side is going to turn on.
Push it to the right and both of the heating elements will turn on.
Idea behind this comes from the commercial background where you save electricity on using only the elements that you need.
the bottom is simply a timer.
you can get an instruction manuat at:
www.dualitusa.com or email your request to:
irene@smithagy.net
Jun 19, 2008 | Dualit 20247 2-Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Replacing the elements on a Dualit 2-slice
You can find out how to replace the heat elements and purchase replacements at the Dualit Repair Center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 05, 2007 | Dualit 20247 2-Slice Toaster
Dualit 20247 2-Slice Toaster Logo
196 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
