I have a Lennox pulse 21 furnace. It will not turn on when I turn it to cool or heat. I checked the main computer module and the LED light is off. I had reset the furnace by using the switch next to the furnace, and this will not turn on the light. Is there anything else I need to check before I call a service tech to look at the main module? The switch to turn on and off the furnace with the removal of the bottom door may be bad. Is there anyway to check this?
  • 107 Answers
The switch you are talking about can be checked. Turn power off to unit. Disconnect wires on both terminals of this door switch. Next use a meter that will show Ohms or just connectivity to see if switch is closed when pressed all the way in. You could use a cheap meter from auto parts store to see if switchis good. You could remove switch and take to automotive parts store and they would actually check for you. If that device is good. Please follow wires from main power and see if there is a fuse before or on the main control board.. There will be a transformer that converts supply voltage to 24 or 28 volts and when turning power on that transformer will become warm and have a very small humming noise.. let me know what you find and if you need anything else.
Posted on Aug 29, 2010
Lennox 80 MGF furnace heat only. Both diagnostic lights are indicating everything is ok with the ignition control but the furnace main fan runs continuously. The fan is on automatic at the stat
So no heating just blower? If you have a g wire on the tstat remove it first. Then possibly a stuck relay. Obviously if the blower stops when g removed the tstat is bad.
Aug 14, 2017 | Heating & Cooling
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
Lennox pulse 21 startup issues .does not engage fan and complete heat cycle every time .
Have seen a rash of faulty blower time delays in lennox equipment. Lennox has a recall on one currently, not sure if your system is effected but it can be bypassed if in fact the problem.
Aug 23, 2017 | Heating & Cooling
Lennox pulse 21 furnace - nothing runs on but control board tries
you will need to verify voltage from the board to the inducer. If you have the installtion manual there is a flow chart for the sequence of operation of the furnace.
The basic sequence is:
1. thermostat calls for heat
2. inducer motor starts and runs for a pre-set amount of time
3. the pressure switch closes and allows for ignition trial
4. ignition is proved back to the board allowing the system to operate.
Verify 120VAC to the inducer motor upon call for heat from stat, if you have 120 at the leads that connect to the inducer and it does not start , the motor is faulty. If the inducer starts use a voltmeter across the pressure switch terminals, a voltage reading of 0 VAC will verify contact closure and ignition should occur.
The pulse furnace was under a factory recall due to breaches in the heat exchanger, unfortunately for you, the Lennox Corp. has ended the program that allowed for an allowance / furnace for replacement. To test the heat exchanger a special kit is required from lennox that will verify integrity of the heat exchanger. (If the heat exchanger seal has been comrimised the pressure switch will not prove and the igniton sequence will be interupted and cause the system to go into "lock-out" mode).I know this is probably not what you wanted to hear. Hope this helps, please list as "very helpful" if it did
May 08, 2010 | Heating & Cooling
Lennox gas furnace G21Q4/5-100-1 sometimes won't kick on
Hi check out the flame senser is clean also jump ou tthe pressure switch see if it lights when you do this , igntion modul is just a box with some push on wires just get the right one the info is all on the module
Feb 16, 2010 | Heating & Cooling
I have Lennox pulse 21 control module light goes out
If this is a high eff model, check to make sure the intake vent is not plugged.
Jan 17, 2010 | Heating & Cooling
No ignition on pulse furnace. runs through cycle trying to start and you can smell gas outside by the exhaust tube
MAYBE the module. If you call for help be sure they know how to work on a Pulse or they're likely to just tell you to replace the furnace (try to find a company that was a Lennox dealer at least 10 years ago). The Pulse is a very different animal that many in my industry don't understand and are quick to fault - the Edsel of the heating industry.
Oct 15, 2009 | Optimus Heating & Cooling
I have a Lennox Pulse furnace. It's making a
The bearings are bad. You need to replace the motor. Motor cost $75 to $125. Labor is on avg. $150 to $400 with an decent A/C Company . You can try to oil it but its not recommend by Lennox. That furnace at the time they build it was top of the line. Good Luck.
Oct 14, 2009 | Heating & Cooling
Very loud induced draft furnace
when you tighted it it very well could have done damage to the motor or you could have it off kilter 1 of the 2
Feb 04, 2009 | Superior Lennox Blower Thermal Sensor -...
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
344 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
