Question about BYTECC Smart Drive PG-350U2 (HDW10X0079001) Drive Case
My new Dell laptob (Impasario Studio 15) won't show any indication of the external hard drive's usb being plugged in. How do I fix this?
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Aug 28, 2010
My Computer not showing my toshiba canvio hard drive
Have you tried shutting down the computer ... unplugging the hard drive ... re-starting the computer .... and plugging in the hard drive (after the system is all ready for use) ?
It's likely the hard drive was "ejected" ... (after defrag ? or when the system went into standby/hibernation) .... and hence you see the icon in the task bar ... indicating that you can safely unplug the hard drive from the computer.
Feb 18, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Apr 23, 2013 | Hitachi Touro Desk 1 TB USB 20 External...
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
Iomega hard drive won't let me view files on my TV
I have suggestion for you please scan your external hard disk with a good antivirus and then anti malware bytes. Possible your problem will be solved. Thank you so much....
May 06, 2012 | Iomega Select 1TB USB 20 Black External...
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
I am having trouble adding a memorex external hard drive/ cd burner unit to my studio slim tower. i plugged it into the front connection. it doesn't registar. what am i doing wrong?
1st make sure the USB port works (try plugging it into a differant USB port, if that still gets no results try installing the driver again that may make all the difference in the world atleast it won't hurt to try
Mar 30, 2010 | Dell Studio Slim-Tower Desktop Computer
How to boot from external hard disk plsss help
You could setup a dual boot system, this requires a fairly large hard disk and you need installation XP and Vista CDs.
The other option is to install XP only on your hard disk.
Mar 07, 2009 | Dell Studio 15 Laptop
Hooking up a
Your external drive has a choice of USB or firewire, so only connect with the USB cable.
Dec 05, 2007 | Western Digital External USB 2.0 80 GB...
BYTECC Smart Drive PG-350U2 (HDW10X0079001) Drive Case Logo
100 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
