Question about Samsung PPM42S3X 42 in. HDTV-Ready Plasma Television
Ppm42s3x controls on bottom locked
The buttons on the bottom of this TV are locked and i do not have the owners guide or the original remote, how do i unlock the TV? not even the power button works, the universal remote will switch it on but it will not let me into the menu to switch settings
  • petdander Nov 10, 2008
    I have the same flat panel with the same problem. Everyone says hold the menu button for 5 to 10 seconds but no go.
  • Anonymous May 02, 2009
    same problem different tv
5 Suggested Answers
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
SOURCE: remote not working!
Hi, I have just had same problem and rang Samsung who sorted it ! All that was required was to reset remote by taking out the batteries then press power for approx 10 seconds and then replace the batteries and hey presto it worked!
Posted on Jan 03, 2009
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
hellopeter
  • 61 Answers
SOURCE: How do I unlock my 42
Reset the TV by unplugging the cord. wait 30 minutes.
Posted on Jun 12, 2010
I have try several times to connect my Welby big button remote control to my Panasonic TV.I have the codes of the TV but I can't get it to work.can someone guide me thru.I will appreciate it.
[PDF]Big Button Universal Remote Control User's Manual
www.magnifyingaids.com/pdfs/Big-Button-Manual.pdf
Big Button functions just like your original remote ... On the remote control, press and hold the MODE button (TV, VCR, CBL/SAT or. DVD) until the .... Q. Why won 't my Big Button work? A. Make .... PANASONIC 008, 051, 057, 076,. 149, 247 ...
[PDF]Big Button Remote Control Set-up Codes - ValuNet
myvalunet.com/.../Remote-Control-Big-Button-Remote-Set-up-Codes.pd...
Innovative System's Big Button Remote Control ... TV. Quick. Number. Manufacturer/. Brand. 0. SANYO. 1. SONY. 2. SANSUNG. 3. LG. 4 ... PANASONIC. 6.
Remote Control Setup, Codes and User Guides - FiOS TV ...
https://www.verizon.com/.../tv/.../remote+contr...
Verizon CommunicationsThis page provides links to setup instructions, remote control codes, user guides, ... No code for my device ... Want to buy the Verizon P283 Big Button remote?
Amazon.com: Gmatrix Big Button Universal Remote Control ..
Dec 14, 2015 | Panasonic Televison & Video
Apex model PF3225, The TV is Locked (blue screen with red key on the bottom left corner). Don't have original remote...please help
Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
Mar 22, 2012 | Apex Digital PF3225 32" TV
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA Televison & Video
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
Mar 14, 2011 | Jensen 143307 Remote Control
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
When I start the TV appers a blue background and whenI touch a button a lock appers on the left corner, bottom. How to unlock the TV?
Sounds like a parental control called front panel lock. You'll need to find the owners guide to reset the Parental control password or deacivate this lock setting. Usually, requires the remote controller too, espec. w/RCA sets.
Is there a MENU button on the panel, and does it ALSO produce the lock symbol? Do you have the remote?
Mar 14, 2009 | Televison & Video
Old remote quit. Need factory replacement
try contacting www.remotes.com for a new factory original remote
Nov 23, 2008 | RCA RCU300 Remote Control
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Tv is locked
I had the exact problem...tried a number of things that did not work. My dog "ate" my original remote. After reading your solution I took the universal remote that was programmed to work with the tv and tried holding down each button for a few seconds hoping that one would work like the display button on the original remote. It worked. I have a GE universal remote and the menu/info button worked for me. Again, you need to hold it in for a couple of seconds. Thanks for the help and I hope my added solution helps other people. Claudia in Minnesota
Feb 15, 2007 | Haier HTF20R21 20" TV
Mitsubishi Rear Projection TV
Easy! But you will need the original remote. On the remote is a button called QV for quick veiw. Press that button at the same time with the 9 button. This will open the lock, But it will return when you turn off the set and turn back on again. If you want it to do a normal turn on , once you open the lock you must go into the menu and remove the lock from the set completely. You may be able to find a friend or a store that might let you borrow an original remote? Sorry to be the bearer of poor news my friend. Good Luck
Aug 08, 2006 | Mitsubishi VS-55707 TV
Samsung PPM42S3X 42 in. HDTV-Ready Plasma Television Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
