Question about Bosch Nexxt 500 Dryer
I have a Bosch series 500 dryer that has stopped working. when i turn it any program the START/PAUSE light starts Flashing as usual and the time shows up on the the display. when I push START the DRYING led lights steady and I here a click but nothing else, the drum does not move and I hear no further sound If I push PAUSE the DRYING led goes off, LINT FILTER led flashes 3 times and then the START?PAUSE light starts flashing again If I turn off the program switch, the WRINKLE BLOCK led lioghts for second and then all lights go off I have turn off the braker for 30min and then turned back on but still have the same problem
    President:
  • 3,074 Answers
Sounds as though the belt maybe off, you will have to disassemble the dryer and investigate. hope this helps tim
Posted on Aug 28, 2010
  • mpasic Aug 28, 2010
    Note to all The wiring diagram for the dryer is inside the back cover tye-wrapped to the frame
    Turns out it was the belt switch. To reset the switch I had to unplug the dryer, remove the power cable and back cover completely. Note last two screws hoding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover .
    On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click)
    Do not push the right button as that is what was tripped originally .
    After I fixed the problem my son admitted he had put some heavy hockey equipmnt on the drying rack.
    Apparently it was too heavy and pushed the rack done stoping the drum from turning. This caused the belt to stretch which then tripped the belt tension safety switch. Wish they would have simplly described the problem in the trouble shooting list in the manual
  • duncmaxwell Oct 24, 2010
    I am SO glad someone else had this problem - you just saved me from an expensive repair bill!
    THANK!
Thanks so much! I replaced the blower fan in mine, and after I got it all back together, it would not turn on.... Since I had removed the drum, and belt, the switch had been triggered... This was the trick... Thanks again...
Posted on Oct 10, 2012
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
Jan 20, 2016 | Bosch Washing Machines
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosch Nexxt 500 series dryer shows an error code of E:22. I'm hoping u can tell me what it relates to. The photo shows what it is doing. Start light and filter light flash but it won't turn on.
E:20 through E:26 Defective control module Unplug the dryer for 3 minutes to reset the control module. If the code returns when power is restored, replace the control module. Control module
Nov 03, 2015 | Bosch Dryers
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
to fix you must do a master reset of the washing machine.
Aug 18, 2015 | Bosch Washing Machines
I have a gallery series dryer and after a short time, maybe 20min, the dryer stops and all the lights on the right side start flashing
Good Morning Catherine Funk, thank you for your post!
From my understanding your Frigidaire dryer will start and stop after 20 minutes, also the lights on the right side start flashing. Could you provide me with your model number, please? You can usually locate it on the door frame of your dryer. With that information I can examine your control board and provide any further assistance. -Matt
Feb 22, 2015 | Frigidaire Dryers
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
I have a Bosch 500 Next series dryer. The dryer now is not working. The lights are on, and they give esitmated times for each drying setting. But when I click start, I hear 2 clicks, and nothing happe
Most Bosh dryer have a high limit sensor inside. Very easy to fix. disconnect power, remove back cover. there is lots of screws. usually torx head. you will see at the bottom of the dryer from the back side that there is 2 wires going to a round black "snap disk". there will be a bottom in the middle push the button in. if this dose not fix your problem you should get a in to fix it.
Jan 21, 2014 | Bosch Nexxt 500 Dryer
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Washer flashing E:
John-I have the same problem. I called service, they told me to unplug it (or turn off the breaker) for 30 mins, then turn back on. That should reset it. However, for me, it didn't do a thing. He said if that didn't work it's time for a service call.
Jul 03, 2009 | Bosch Nexxt 500 Plus WFMC530SUC
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
1,009 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
