Question about Nikon D50 Digital Camera with 18-55mm Lens
Err I get an Err message after taking a photo, the photo has a black edge along the bottom of the photo. like it is under exposed. do you have any idea what my camera might be doing? I recently added a speed light, and after only using it a few times now my camera is giving me problems.
  • cplariosa Jul 03, 2008
    I have a problem with my nikonD50, it shows "err" on the display and I can't take pictures anymore. any solutions how to fix it?
  • Anonymous Jul 28, 2008
    I have a Nikon D50, after taking a photo, it shows a black (line) edge on the lower side of lcd/computer screen which even appears on a printed picture.what could be the problem?HELP.
    My lens Sigma 28-200 is okey with it.
    Jash
    Novelist:
    Champion:
  • 214 Answers
If this only happens when using the flash - then it is a problem of flash synchronisation.
If it happens all the time - then one of the shutter curtains may be sticking.
Either way, you should get the camera looked at by a repairer.
Posted on May 11, 2008
How do I save my pictures I take from my phone onto my phone ( GALAXY NEXUS )
You can either connect it directly to the PC. Normally photos saves on DCIM folder or else you can download dropbox on your PC and on your device, and it will sync automatically whenever you connect with wifi (by default)
Mar 29, 2014 | Microsoft Internet Explorer 7
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
Camera has taken photos fine in past- now when I try to take a photo I get the message "memory card protected" and I cannot take the photo. How do i remedy ?
You didn't specify the model of your camera, so I'm assuming it uses SD cards. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 05, 2011 | Cameras
I am unable to take photos with my samsung digimax s800 camera as the message 'CARD LOCKED' keeps coming up on screen. I have deleted loads of photos so the memory card is definitely not full. Any ideas?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 17, 2010 | Samsung Digimax S800 Digital Camera
Nikon D90 ERR message after taking picture -
Is there a memory card in the camera?
Also try cleaning the contacts on the lens (light rub with a pencil eraser works).
Aug 07, 2009 | Nikon D90 Digital Camera with 18-105mm...
Compaq A1500 all-in-one/message:clear system err then press clear
1. Lift the control panel by grabbing the panel along
the top edge.
2. Pull the control panel forward.
3. Lift the ink cartridge access door. For better
access, stow the document input tray away. The
cartridge carriage will move to the center.
4. Remove the new ink cartridge from its
packaging. Hold the ink cartridge by the black
areas or colored top only.
5. Remove the tape covering the print head by
carefully pulling on the yellow tab. Be sure to
remove all of the tape.
May 25, 2009 | Compaq A1500 All-In-One InkJet Printer
HOw to get into engine to change spug pluggs and leads for Toyota estima 1993
The best thing to do is to purchase a Haynes manual for the Toyota Previa. But to access the spark plug wires and spark plugs you will need to remove the passenger front seat. This requires taking out four bolts on the four corners of the seat. After the seat is removed you need to remove the outside seat support and the jack and jack handle that is located under the seat. Next remove the bolt from the seat belt/shoulder harness. Romove the screws from the side of the carpet keeper strip along the bottom of the door. carefully, using a flat blade screwdriver, pry the plastic carpet strip up carefully disengaging it from the rear strip. Unhook the carpet from the edge of the doorway. Pull the carpet back enough to expose the bolts holding the cover over the engine. Remove all the bolts holding the cover over the engine. This will expose the engine head. remove the three bots holding the black plastic cover over the spark plug wires. This wires can be removed allowing access to the plugs. Be aware these engines use only platinum tipped spark plugs. Good Luck
Nov 21, 2008 | 1993 Toyota Previa
Nikon D50 Digital Camera with 18-55mm Lens Logo
93 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
