Question about LG Washing Machines
What does a flashing code of "FE" mean? I cannot get the machine to stop beeping nor can i unlock the door?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. FE is Overflow error which means that the water is overflowing and the water level frequency is over 213. When FE error is displayed the drain pump operates to drain the water automatically. To resolve this issue you’ll have to check the water inlet valve and pressure sensor which can sense the water level in the tub, if any of this goes bad overflow occurs. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
My Samsung Washer has a code of 1E which means maybe the water level. My problem is that it want turn off. Even when I push the stop button. The door is locked and it keeps beeping and flashing
1e is usually a pressure sensor error. To open the door you will need to switch off the appliance at the wall then after about 2 minutes the door should unlock. You could try the appliance again as it may just be a glitch but you will probably need the pressure sensor.
Good luck.
Dec 17, 2015 | Samsung Washing Machines
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Whirlpool duet washer error code h
go to the manufactures website and download the user manual its normally a free download and look in the problem shooting section eric
Dec 27, 2017 | Whirlpool Duet GHW9150P Front Load Washer
When the wash cycle is going it starts to make a tune and then FE starts flashing I need to know what FE means
Hi there Celina the code FE has a few differant meanings depending on the dishwasher model. If you can provide me with the model code I can help you with this problem.
Nov 21, 2011 | LG Dishwashers
Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
maximum oven door unlock time exceeded. Check wiring between eoc & door lock micro switch. more likely you need to replace the EOC
May 19, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Model Ghw9150PWO beeps and flashes F then H then stops.
F/H= No water detected entering the machine make sure your valves to the machine are on do that and we will go from there
Apr 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
267 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
