Question about McCulloch Heavy Machinery
I have a mac 335 electrolux vortex air system chain saw which does not start up.
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
  • 120 Answers
SOURCE: I have a Mac 3214 chain saw and I do not have the mix ratio
40 to 1 is the ratio
Posted on Jul 11, 2009
  • 26 Answers
SOURCE: 55cc air induction chain saw wont start,keeps flooding
what do you mean by flooding?
if it is overflowing?
try to remove the 4 screw underneath the carb,
take out the diaphragm,and then followed by float valve..
there is a tiny spring,be very careful...
stretch the spring a lil bit more at about 2mm...
as time passes,the diaphragm deteriorate and one way to correct them is by stretching the tiny spring to give more strain on the diaphragm...
this is what i did if i am too lazy to go out and buy the diaphragm kit..
only 10 bucks...hehe
Posted on Aug 06, 2009
dontbother10
  • 2220 Answers
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Posted on Jan 07, 2010
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
My chain oiler is not working on my MAC 335
Sounds like something is clogged. I recommend contacting your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jan 02, 2013 | McCulloch Garden
Chain is coming off after 5 mins work
The chain has too much slack.
Look in the manual
The chain needs to be tightened so that there is only a small sagging of the chain on the bottom of the saw.
Looking down at the saw there is a round knob just behind the saw blade.
Make sure the saw chain is in the guides.
Turn the knob counter clockwise to loosen and then clockwise to tighten the saw chain.
Jul 26, 2012 | Garden
What Oil is used for the bar & chain lubrication
Hi khipiercy...
You will use "Bar and Chain Oil" for your chain and bar lubricant...it is specially formulated to be used on chains and bars of chainsaws...
You can buy it at any Loews,HomeDepot, Ace Hardware, etc.
Please take time to rate me
Sep 22, 2011 | McCulloch Garden
What is the correct fuel for a mac 335
Unleaded fuel mixed with good two stroke oil at a ratio of 25-1
Aug 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How do you get the sidecover back on over the clutch drum on a McCulloch MAC 335 Chainsaw? The sidecover does not seem easy to remove or put back on which is annoying when you need to put on a new chain....
Hi Hamish,
You don't remember how you took it off? Well, that happens sometimes... :>)))
Pull the chain bar away from the sprocket as far as you can move it, then rotate the adjustment knob handle into its original position. You may have to pull the chain brake back if you bumped it into the lock position while working on your saw.
If you need any more help with your chainsaw, ehow.com has full explanations on just about everything. Just type in "how to ..." with your problem and articles and videos are available.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 25, 2011 | Garden
Put a new chain on a macullock 335 saw it start
Remove the spark plug when it quits to check for good blue spark. If ok, squirt some starting fluid into the plug hole, replace the plug, and try to start. If it pops a couple of times, then you have fuel problems. Check the condition of all fuel lines for decay or splitting. Make sure the air cleaner and muffler are not plugged. Check the fuel filter inside the fuel tank for plugging. If everything looks ok, then it is likely time to clean and re-kit the carburetor. Basic setting for both jet needles is 1-1/2 turns CCW from CW stops (lightly). If everything is in order, it should start and run. Allow the engine to warm up, then apply full throttle and adjust the H needle CW until it picks up speed, but still 4-strokes. It should immediately start 2-stroking when cutting. Allow to idle and adjust the L needle so that the engine idles fairly smoothly, yet allows the engine to 'follow-the-throttle'. Hope this helps!
Apr 05, 2010 | Garden
I own a McCullogh 610 Pro mac chain saw. Why does
Check the muffler to make sure that the spark arrestor screen is not plugged. Make sure the air cleaner is clean and not plugged. Turn both L and H mixture screws CW to stops (lightly), then back out 1-1/2 turns each. Warm up the engine, then open the throttle and turn the H needle CW until the engine speeds up, but still '4-stroking' but should immediately start '2-stroking' with light cutting. Release the throttle and adjust the L needle CW for fairly smooth idle, yet rich enough to allow the engine to 'follow the throttle' immediately when accelerated. Adjust idle speed CW until the chain starts to turn, then back off until it quits turning. Make sure the chain is being properly oiled and is adjusted for no chain droop, yet turns freely by hand. Hope this helps!
Dec 27, 2009 | Garden
I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Oct 08, 2009 | McCulloch Garden
Can't rememeber what fuel or oil it needs and how to start it
Start with a 40-1 mixture this should not hurt engine for a long time if you are just a casual user. The oil in the chain reservoir is chainsaw bar oil and I usually top off each time I refill the fuel. To start Turn on switch, close choke, hold throttle to open position, You may need to place saw on the ground hold down with foot in the handle while pulling cord. Once it tries to start place choke in mid position and try to start again. Once it is running place choke in full open position.
Apr 11, 2009 | McCulloch Garden
Heavy Machinery Logo
271 people viewed this question
Top McCulloch Heavy Machinery Experts
Tom Chichester
Daryl Gleaton
Bill Boyd
Are you a McCulloch Heavy Machinery Expert? Answer questions, earn points and help others
