Question about Casio Exilim EX-S600 Digital Camera
Battery charging light comes on (Red) for a few hours, then the Green charge completed comes on. Pressing the camera power on button causes the camera power on light to flash for a fraction of a second and the camera is dead. Tried brand new battery but the results were the same.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
Just got a new battery off Ebay..Installed in the camera and a red light came on..Does that mean that its charging or does a green light means that its charging?..Does the red light suppose to go off and...
Answered this one earlier-
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
Nov 05, 2010 | Sanyo Xacti VPC-T700 Digital Camera
I have a Sanyo T700 camera. Just got a new battery off Ebay. I inserted it inside the camera and a red light came on. Does that mean the battery is charging or does a green light mean that its...
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Mar 11, 2010 | Archos Internet Media Tablet MP3 Player
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
I have been charging my vivitar vivicam for probably over 24 hours and it still does'nt work.
Your problem is likely either the charger or a battery that's too worn out to take a charge. A constant red light on the charger indicates that the battery is charging, and a green light indicates that the charge is complete. If the green light never comes on, that's a good indication that the battery is beyond charging. If you have a voltmeter you can check the charger output and the battery voltage. Unfortunately your camera uses a special battery so there's no way to test the charger with another battery or to test the battery in another use. Replacing the battery, especially if it's more than a year old, is your best bet.
Dec 13, 2009 | Vivitar ViviCam 8025 Digital Camera
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
It won't turn on! I charge it, and the camera is no more than a year old, and yet it wont turn on. However, when it's on it's base, it can connect to my computer and turn on fine! Is it the battery?! Why...
Mine won't turn on...unless I hit the red button, then the menu button, then repeat...the red, then the menu. When the menu comes up, it wants to reset the date/time etc. I just ignore that and hit the menu button once more and it's ready to shoot. Pain in the you know what.
No more Casio cameras.
Jun 26, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Video camera jazz dv179 how many hours need to charge
I HAVE THE SOLUTION!!!!! the camera comes with a charger that plugs into the wall and into the usb port on the camera
Oct 27, 2007 | Jazz DV-179 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
26 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
