Question about Frigidaire FAC126P1 wall/window Air Conditioner
How to remove the front panel holding the air louvers...
We have a FAC127P1A and if you gently pull the lower cover by holding each side where there is an indentation it will lower so you can get to the filter. Then either replace or wash the filter. We have another model, FAA087P7A1, and we were able to pull the cover down and lift up slightly and remove the cover and wash to remove the collection of dust, etc.
On this latter model there is a collection of dust, etc. in the area where the cooling is blown into the room that I would like to know how to remove for cleaning. I feel it is unhealthy the way it is now and would like to clean it before removing for the season. I know I could use q-tips or a small piece of cloth to clean but that is pain staking.
Any help would be appreciated. Thanks.
Posted on Sep 04, 2010
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
May 02, 2015 | 1997 Dodge Grand Caravan
How to remove cover on indoor unit of Fujitsu aotr30l ct
Undo the screws at the bottom and on the front panel. There may be one behind the power cover as well. You may have to remove the horizontal louvers but be careful because they have a spring or two to assist the louvers swinging and can fly off. When you are sure all the screws have been removed, you will have to use a flat screwdriver to gently lever off the plastic hooks holding the top of the cover to the back - one at each end and one in the middle. Try to see with a torch and be careful not to break the plastic or damage the heat exchanger. The cover comes off best from the top forward.
Also, there may be a couple of hooks under the bottom edge as well. They come loose by pushing up at the bottom edge where the small arrows are.
Jan 17, 2015 | Fujitsu Heating & Cooling
Horizontal louvers
Get yourself up to the machine on a safe platform. Remove any covers that will come off easy, or tie them up out of the way. Remov e the filters. Often the whole front can be removed by just taking out a couple of screws.
Once exposed, look for something out of place. Put the louver back where it belongs to see how the hinge works. It may have jumped out of it's proper position. Ease it back in position and check it for freedom of movement. If it looks good, put it all back together.
Nov 26, 2013 | Carrier Heating & Cooling
How do I pull out the air conditioner from the sleeve? Something is holding the middle of the louvers preventing me from pulling out the ac. Help
if its getting hung up on the middle of the louvers check to make sure nothing has pushed the louvers in ,in that spot. Also look inside after you have front cover off to make sure all screws are out and it can have a simple catch lock on the inside to avoid accidental slide out.
May 27, 2013 | Friedrich QuietMaster Electric SS10J10AR...
My haier air condition doesn't have anything on vent to get cool air\r\ni believe it had styrofoam which got thrown away because we though it wasn't needed
I don't think a piece of thrown away Styrofoam is the problem. I'm more concerned that you may have also thrown the Owner's Manual away too. You said, "there's nothing on the front to get cool air in." Are you saying, that the front of the unit that has fixed louvers at the bottom and adjustable louvers at the top is missing? Because that's where the cool air comes out thru the adjustable louvers), when the unit is in operation. If the entire front of the unit is missing and the unit is brand new, you need to contact retailer you purchased it from ASAP.
I hope this helps and thank you for choosing FixYa.
Jul 29, 2011 | Haier HWR08XC7 Air Conditioner
My air vent louvers are broken on one of my dashboard vents. Is it easily removed to be replaced or repaired.? 2005 Dodge Ram
Chances are the louver is toast. They are relatively easy to remove. Pry gently at the top and bottom of the louver with a small flat screwdriver. The two pegs holding it in place should pop free. You will probably find that one or more of the tiny plastic pins are broken.
The dealer should carry them but I am going to start looking at the junk yard first.
Hope this helps.
Mar 28, 2011 | 2005 Dodge Ram 2500 Truck
Is there a replacement thermometer? the compressor will not cycle
This is not a solution, but---. I had to set thermostat all the way up to 86 (high as it would go) and remove front panel entirely. It now cycles OK on energy saver but will sometimes get too cold. Seems any blockage of air flowing out into the room will negate cycling on/off. I've totally blocked intake to coils with no effect on cycling. Any time I replace front panel (with louvers) the system doesn't like me. I'm still searching for correct solution.
Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
The turn on lights does not flash
Check out this recall below:
Bulletin No.: 04098A
SPECIAL POLICY
Subject:
04098 - Special Policy Adjustment - Turn Signal/Hazard Warning Flashers
Condition
Some customers of 1999-2002 Chevrolet Malibu, Oldsmobile Alero, Pontiac Grand Am, and 1999 Oldsmobile Cutlass may have turn signal/hazard flashers that become inoperative.
This special policy covers the condition described above for a period of 10 years or 150,000 miles (240,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
Good luck and hope this helps:
HAZARD WARNING SWITCH REPLACEMENT - ON VEHICLE
REMOVAL PROCEDURE
Remove the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
Remove the instrument panel cluster.
Remove the hazard warning switch bezel from the instrument panel using a small-flat bladed tool to release the retainers.
Remove the left side bolt from the hazard warning switch through the instrument panel cluster pocket Remove the right side and center lower bolts from the hazard warning switch through the center air louver deflector pocket.
Reposition the hazard warning switch from the instrument panel to access the electrical connector.
Disconnect the electrical connectors from the hazard warning switch.
Remove the hazard warning switch from instrument panel.
INSTALLATION PROCEDURE
Connect the electrical connectors to the hazard warning switch.
Position the hazard warning switch to the mounting points in the instrument panel. NOTE: Refer to Fastener Notice in Service Precautions.
Install the left side bolt to the hazard warning switch through the instrument panel cluster pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the right side and center lower bolts to the hazard warning switch through the center air louver deflector pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the hazard warning switch bezel to the instrument panel pressing into place until fully seated. Install the instrument panel cluster.
Install the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
May 24, 2009 | 2000 Oldsmobile Alero
Dashboard Gauge
  1. Disconnect and isolate the battery negative cable.
  2. Remove Over Steering Column Bezel Replacement.
  3. Remove over steering column bezel.
  4. Remove left end cover.
  5. Remove screw at left end of cluster bezel and headlamp switch.
  6. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  7. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
    1. Separate cluster bezel from instrument panel.
    2. Disconnect wire connectors from back of the bezel.
    INSTALLATION
    I wouldnt Recomend This Procedure To Anyone juse for Cleaning Purposes Unless Your VIEW OF IT IS "SERIOUSYL IMPARED IF it Moisture Has Accumilated Behind Face of it Then Find Out WHY and Resolve THAT PROBLEM FIRST Onherwise Here you Are. Have A Great DAY !! And Please Dont forget to RATE Me Thank You !
Jan 15, 2009 | 1999 Dodge Caravan
Frigidaire FAC126P1 wall/window Air Conditioner Logo
704 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
