Question about IBM TravelStar 40GN 40 GB Hard Drive
MY 40GB USB2.0 cannot be detected by any PC. I can hear the motor spon and the Red LED also display but PC cannot detect the disk. pls advise.
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Aug 28, 2010
  • IBM Master
  • 11,800 Answers
In that case the disk or its case has died. Take the disk out of the case and put it directly in a desktop. If now it's recognized and accessible then the case has died - if not then the disk itself has died.
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Dsk drive will not open and acer will not boot
When you bootup and the power LED is on and the hard disk is spinning and the hard disk LED is flashing, then the hard disk is most likely OK.
Check the BIOS setting to see if the hard disk is detected.
Reseat the RAM moduled and the hard disk and see if this solves your problem.
Do you see any error messages on the screen?
If so please give me the details and I can advise what actions to take next.
Jul 16, 2009 | Acer TravelMate 290 Notebook
IBM THINKPAD 600 can't detect HARD DISK FUJITSU 40GB. what can I do???
Check the power cable of harddisk if found it is ok then go to bios and detect the harddisk by pressing enter on primary boot device
Jun 01, 2009 | IBM ThinkPad 600E 2645 Notebook
40GB portable Hard disk !!!
try go to hardware management. there you check if your harddisk is deactivated or if there is a problem.
please contact me if it doesn't work.
CS
Jun 01, 2008 | SimpleTech Computers & Internet
HDD not detected
plz try in another pc, if the problem remains then you contact the vendor
Apr 23, 2008 | Seagate Notebook Hard Drives: 40GB...
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
IBM TravelStar 40GN 40 GB Hard Drive Logo
277 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
