Question about Whirlpool Dryers
I have a used dryer that 4prong electrical cord and my old unit only uses 3
    President:
  • 3,074 Answers
You can change the cords it is easy, take the back plate off both machines and wire the three the same as the old one. Hope this helps tim
Posted on Aug 28, 2010
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
What type of power cord do i need?
An electric dryer has an opening in the back, older units use a three prong cord, there will be three posts to attach cord, newer units have four prong cords, Bought separately. there will be four posts to attach, double grounded cord.
Jan 17, 2013 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Converting a 3prong to 4 prong electric outlet, need order of colored wires
call an electrician before you kill yourself or burn down the house
Feb 20, 2018 | Kenmore Elite HE4 Electric Dryer
How do i go from a 4prong to a 3 prong
Go to this website, they have a page to help you connect your dryer.Please rate mehttp://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Dec 04, 2010 | Estate TEDX640JQ Electric Dryer
Does this washer dryer need to have a ground fault plug in?
Hi!!
No, the washer/dryer does not need a GFI, it is well insulated an all electrical components that even if you had a water leak, and touch the unit, it will not shock you. What is needed is a 3 prong connector, this extra ground prong will increase the protection against a electrical shock. I have seen people that removes this prong so they can use an extension cord, it is not recommended to use extension cords with this units, but in case that you must use one, make sure the extension cord has 3 wires and an AWG rating larger than the load is going to carry to prevent overheating and possible fire hazard.
Most homes are equipped with a dedicated outlet for the washer/dryer. If your unit is connected to one of those outlets, you have nothing to worry about.
Good Day!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 18, 2010 | Splendide 2000S Vented Washer/Dryer
Trying to replace a 3prong plug with a 4prong plug
Ok, so you currently have a three prong cord on your dryer? Your house has a 4 prong receptacle? Ok so now you've purchased a 4 prong dryer pigtail? Be sure cord is unplugged. Remove cover of junction in back of dryer. You will see three terminals. They should be labeled something like L1,L2,N . ON one terminal you well see a small ground strip This is currently connecting the neutral terminal to ground. On the new cord connect the outside two conductors to L1 +L2 connect the white conductor to the N terminal. Connect the green (ground) conductor to the frame where the copper bonding was. This seperates the neutral conductor from the equipement grounding conductor.
Jul 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I need to change the dyer cord from a 4prong cord to a 3prong cord. Is it possible? It is model number M90825760.
If you have a digital camera, you could take a picture of the plug (several different angles) and your outlet then go to one of the large chain hardware stores, camera in hand, and ask for an adaptor between the dryer's plug and your outlet. It may not be necessary to rewire the dryer at all. If they don't have one, keep reading.
The change probably is possible since dryers generally use a 2-phase connection at the most but I wouldn't recommend that you DIY. You are dealing with a line voltage whcih could be 220 and a circuit capable of supply fairly high (20) amperage.
This combination could make toast out of you if improperly wired. Any competent electrician can determine how to do the conversion with a few measurements.
There is an exception; some mfr.s have pasted a large label either inside or out on the larger panel that contains the electrical diagram of the machine.
With some care, most laymen could determine how to make the change.
Mar 03, 2009 | Kenmore 62622 Electric Dryer
Dryer sat outside for 5 months
You need a test instrument called a megger to tell the value of the insulation of the machine, one thing you can do is use an ohm meter between the power leads and frame, if you have a lot of resistance it is likely you can use it.
Is it inside now in a temp controlled area?
Can you get the back off with taking out probably several screws to expose the insides?
If so you can set a heater with a blower by it and blow warm air inside to dry out any wet insulation, the goal is to make sure no insulation anywhere, controls, wiring, motor is still wet and will conduct when you first plug it in.
Nov 14, 2008 | Dryers
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Whirlpool Dryers
Dryers Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
