Question about Honda 25cc 4-cycle Mini Tiller
While operating the Honda FG-100 mini tiller, the tiller suddenly stopped turning. The engine runs fine. I couldn't find any advice in the manual. Any help would be greatly appreciated.
    Problem Solver:
  • 5 Answers
If the tines become jamed, the tiller will stop. This is especially true if you are preparing your lawn for seedng without doing an preparation of the ground. Also, check you accerleration line, there may be a loose connecton.. Otherwise, sounds like a service issue.
Posted on Sep 06, 2010
I need a Primer Bulb for my FG-100 in North Atlanta, Any ideas?
Miker77506, I have the same model mini tiller if you are looking for parts: http://www.alamia.us/Honda_FG100_parts_s/777.htm
Also a local lawn mower shop. Good luck
Apr 25, 2012 | Honda 25cc 4-cycle Mini Tiller
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a honda FG-100 It has a new carb on it but the primer bulb will not prime. blows bubbles back in the take but wont **** gas.
This happens all the time. The hoses leading to the primer bulb are on backwards.
Switch them and you'll be fine
Mike
May 16, 2010 | Honda 25cc 4-cycle Mini Tiller
I'm looking for an online maunel for my Harmony FG 100 mini tiller.
You can download (free) or purchase an OM containing a small parts list here (yours is a mini tiller):
http://www.hondapowerequipment.com/products/manuals/Default.aspx
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 14, 2010 | Honda Garden
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Oct 10, 2009 | Honda 25cc 4-cycle Mini Tiller
Honda fg 1oo won't start
It can be fixed take it to a small engine (lawnmower) shop
May 20, 2009 | Garden
Dethatcher pins on my accessory for the honda FG 110 are broken
MANTIS TILLERS USE THE SAME ATTACHMENT CALL THEM @1 (215)355-9700
Jan 29, 2009 | PDP Systems Dethatcher Attachment for...
Honda 25cc 4-cycle Mini Tiller Logo
646 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
