I have two Phaser 8400 printers both have streks and smears when printing. I am pretty good with machines but I have never taken one of these apart. Can the printheads be cleaned? I really do not want to invest several more hundred dollars, but these do a great job when they are working, and i have several hundred dollars of supplies left.
  • Mike 2 Aug 28, 2010
    The self cleaning including loading pages that are pure color has not worked. I did contact an online outfit that said they owuld do the repair of an 8400 for a flat fee of $150.00 per printer. What I am concerned with is that they may have been moved HOT. If that happened then I guess the wax ink would be everywhere, and that is what I am concerned about.
    Mike R
  • 4,323 Answers
Hi
You can clean the ink loader and print head by removing the ink loader. Please follow the below steps to remove the ink loader--
Control Panel Cover
1. Open the Exit Cover.
2. Using either your fingers or a small flathead screwdriver, loosen the Control Panel Cover on the left side, and then slide it forward while lifting up to remove it from the printer.
Control Panel
1. Remove the Control Panel Cover
2. Disconnect the two wiring harness connectors and one ribbon cable connector from the back of the Control Panel.
3. Remove the Control Panel.
Right Side Cover
2. Remove the Control Panel Cover
3. Open the Front Door.
4. Remove the rear screw.
5. Pull forward on the latching tab located by the power plug to release it.
6. Release the front latching tab and pull out on the top to remove the Right Side Cover.
Continued...
Posted on Aug 28, 2010
  • Daniel Scott
    Daniel Scott Aug 28, 2010
    Left Side Cover
    2. Open the Exit Cover and Front Door.
    3. Remove the rear screw.
    4. Release the latching tabs and remove the Left Side Cover.
    Exit Cover
    1. Remove the Right Side Cover
    2. Remove the Left Side Cover
    3. The Exit Cover will now just lift off the printer.
    Replacement Note
    Lift the upper exit guide slightly, and engage the pins on the upper exit guide with the slots on the Exit Cover before inserting the cover hinge pins into the pivot points in the printer frame.
    Ink Loader
    3. Remove the Exit Cover
    4. Lift the Ink Loader clear of the chassis and hold it in position against the rear of the chassis to allow access to the connectors. For 8400, the Ink Loader disconnects from the printer frame. For 8500/8550/8560, the harness that plugs into the right side frame disconnects directly from the Ink Loader.
    Note
    Hooks on the bottom of the Ink Loader allow it to hang on the rear of the printer chassis while the connectors are removed.
    5. Disconnect the 2 connectors from the printer and remove the Ink Loader.
    Replacement Note
    For the 8400, route the gray harness from the chassis between the Ink Loader and printer side. The harness from the Ink Loader must be routed towards the left side (see inset).
    Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
    Daniel
  • Daniel Scott
    PS--- Smudges or smears appear on the page. The likely cause is ink residue in the media path. Check for residue on the rollers, Stripper Blade, guide ribs, or inside the Preheater. High coverage images with small margins may leave ink debris on the Stripper Blade which is then re-deposited on other pages. This condition usually self corrects (the debris is “cleaned” off the blade by lower coverage images).
    Note:
    To avoid future problems, select "2nd Side" as the paper type if manually printing duplex with preprinted solid ink images on the reverse. This reduces Preheater temperatures to prevent partial
    melting of the preprinted image.
    Daniel
  • 712 Answers
1. Cleaning a printer's printheads is an easy process. Here's how it works (in Windows). Click the Start button (or in Vista the Windows icon) at the lower left corner of your screen.
2. Click on Control Panel. Next, choose Printers and Other Hardware, and then View Installed Printers or Fax Printers.
3. When the Printer page opens, right click on your printer’s name, and choose Printing Preferences.
4. Choose Maintenance. Most printers should have a very similar set of options.
5. The first button is for cleaning the printheads. You’ll have to choose which printheads you want to clean. The best bet is to choose All Colors.
6. Make sure the printer is turned on and that there’s some paper loaded. Now click Execute.
7. The printer will print out a pattern with a grid along the top and six bars of different colors. Two images will display on your monitor that you can compare to the printed image. In one, the grid and colors are sharp and clear; in the other, some of the grid boxes are missing and the colors are striped.
8. If the printout matches the sharp, clear image, simply click Exit and you’re done.
9. If the printout has missing grid boxes or stripes, then click Cleaning. Once that’s done, you’ll repeat the whole process so you can ensure the cleaning was completely successful. It may take two cleanings if your printheads are really clogged.
10. If, after two cleanings, you’re still getting a poor result, there’s a Deep Cleaning option on the Maintenance tab that should do the job.
Xerox Phaser 8400 prints pdfs in half page
I've seen this issue on some of my other Xerox machines (not the 8400 specifically). 9 times out of 10 the solution is to update both the printer driver to the newest version, as well as updating Adobe Reader to the newest version.
Here are the links to each:
Xerox Phaser Drivers
Adobe Reader
May 04, 2011 | Xerox Phaser 8400 Laser Printer
Why is my Phaser 8400 leaving black smears on my printed pages and after running remove print smears, it doesn't correct the problem.
Have you looked at the roll in your maintenance kit? It may be dry in that area and not applying enough lubricant on the drum. Or you have some contaminant on the print head wiper blade or the mylar strip in the maintenance kit. Sounds like something is making contact with the drum causing your problem.
Mar 03, 2010 | Xerox Phaser 8400 Laser Printer
One side of the drum picks up the print from other documents and smears the print on to fresh documents. How do I clean the drum?
You don't clean the drum. You either need to replace your maintenance kit , or my better guess is your using generic ink sticks and you need to use the sticks xerox makes for the machine.
The problem is that your not getting effective cleaning from you maintanance kit
Feb 26, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 error
When you power on the unit it goes through a series of tests to determine that the correct voltage is going to each system within the phaser. The error code you've provided implies a Preheater error 37,008.44
AC power supplied by power sources such as uninterruptible power supplies (UPSs) or DC-to-AC inverter systems may not supply correct voltage to properly power up the printer. Likewise, other devices sharing the same AC circuit can cause AC voltage sags that cause the printer to fail its AC heater PEST tests (Print Engine Self Test).
My first suggestion is to remove any other devices from the electrical outlet the printer is on, and then power it on.
If the error persists, you've got a hardware failure internally and would need to replace the preheater and deskkew assembley, Xerox PN 119641980
By the way, the last 4 digits in your error code are the current page count of your printer. This number is relatively low and thus it begs the question is the printer still under warranty? The part in question is about $110, however installing it will not be an easy task if you've never taken a Phaser 8400 apart or you do not have a service manual.
My suggestion, if the machine is out of warranty, is that you bring it to a qualified repair technician for service, unless you feel comfortable doing the repair yourself.
best of luck in any regard
Sep 01, 2009 | Xerox Phaser 8400 Laser Printer
8400 Phaser has paper jams which leave junk on the drum.
hi david i hope i can help you? you may need to give the machine a good clean, if there is any rubber wheeles? give them a clean with meths. little rollers check to see if any carbon brown in colour. its caused by constant use. i hope this has helped you? top tip you must make sure all the brown is completly away. to make your machine run better.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Blurry Printing
Quite possibly, your Wave Amp board has failed. If so, it is more cost effective to purchase a new printer than to repair yours unless you can find used parts.
Currently, Xerox is offering a trade-up rebate on new solid ink printers.
Mar 26, 2009 | Xerox Phaser 8550DT Thermal Printer
Clean an 8400
Replace the maintenace kit and then in the menus run eliminate light stripes and eliminate smears.
There really isnt much else to do.
What you do when you run the light stripes and smears modes the machine removes all the ink from the print head, turns on a compressor and blows out the jets on the print head.
There really isn't a "cleaning " procedure as with a laser printer. If the maintenance kit is good, it pretty much maintanes itself.
Jan 06, 2009 | Xerox Phaser 8400 Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox 8400 light printing
No, If one lamp goes out they both will not function. They do not have anything to do with print quality.
You may have a bad maintenance kit. but more than likely you have a bad print head.
Run the cleaning , eliminate stripes and eliminate smears modes. But more than likely the print head is bad. I would say a bad print head is about a 95 percent chance of causing your problem.
The halogen lamps only heat the drum, and if one was bad the machine would fault out with a 15,004 code.
Oct 11, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
42 people viewed this question
jasbo
jasbo
