Question about Linksys Computers & Internet
How do I install a password for a links system wireless router
  • 4,281 Answers
You need to enable WEP security in router follow below procedure to secure your wireless network.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP security and enter WEP key it is your password to connect wifi.Then save settings and restart router . Then when anybody try to connect your wifi it ask for that password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 28, 2010
Problem with D-Link 1360 n access point. Not able to visit ip address 192.168.0.50
The internal Wi-Fi radio is enabled by default on most new wireless routers.
However, if you purchased a D-Link router used, you may find that the internal radio is disabled because the previous owner had an exclusively wired network and wanted to eliminate the possibility of a hacker breaking into one of her computers.
Enable the Wi-Fi radio on your D-Link router to enable your computers to connect to the Internet wirelessly.
Connect the router to your computer using an Ethernet cable.
Open a web browser and browse the IP address "192.168.0.1."
Enter the username "admin" and leave the password blank.
Note that these are default values; both the user name and password can be changed.
Click the "Setup" tab at the top of the screen, then click the "Wireless Settings"
Scroll to the bottom of the screen and click the "Manual Wireless Network Setup" button.
Place a check in the box labeled "Enable Wireless" and click "Save Settings."
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamationmark! or a red Xright click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
If you cant install the driver
Make sure you Ethernet/internet is enabled in biosrestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigateto integrated peripheralslook for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
D-Link Wireless Router
D-Link routers use the connection from your Internet service provider to create a wireless network for the various Wi-Fi- enabled devices in your home or office.
Once the router is installed, you can truly enjoy the portable capabilities of your laptop or other wireless device.
D-Link routers have a straightforward installation process, despite the advanced technology behind wireless equipment. So there is no reason to wait around for a technician to help you install your wireless equipment. Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in.
This will reinitialize your modem and force it to establish a connection to the D-Link router.
Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser.
Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field.
Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network.
Click "Apply" to save the changes to the router's settings.
Network D-Link wireless
Type the router IP address, "192.168.0.1", into your Internet browser. Press "Enter" on your keyboard.
Enter your username and password to log into the D-link configuration panel.
By default, the username is "Admin" with a blank password field.
To prevent outsiders from being able to access your D-link router's configuration panel, change the username and password to something more secure.
This can be done by selecting "Tools" from the menu and selecting "Admin."
Select "Administration Settings" and enter your new username and password.
Save your changes by clicking "Apply."
Enter the IP addresses for the computers you want to give access to your router.
You can do this by clicking the "DHCP" link underneath the "Home" tab.
Click "Apply" to save the IP addresses.
Select the "Wireless" link underneath the "Home" tab.
Enter a name in the "SSID" field to identify your wireless network.
Choose "WPA" for your "Security" option.
WPA will provide the highest level of security for your wireless network.
Create a WPA password to access your wireless network.
For maximum security, enter a combination of numbers, letters, and symbols.
Store your password in a safe place in case you ever forget it.
Click "Apply" to save your settings.
Install a software firewall program on your computer to add an additional measure of security for your wireless network.
A few of the popular firewall programs available are Norton Antivirus, McAfee and Zone Alarm.
Mar 18, 2014 | D-Link Wireless N Access Point Dap-1360 -...
Only lights stnadby lamp
Turn on the Wi-Fi on a D-Link Router
The internal Wi-Fi radio is enabled by default on most new wireless routers. However, if you purchased a D-Link router used, you may find that the internal radio is disabled because the previous owner had an exclusively wired network and wanted to eliminate the possibility of a hacker breaking into one of her computers. Enable the Wi-Fi radio on your D-Link router to enable your computers to connect to the Internet wirelessly.
Connect the router to your computer using an Ethernet cable. Open a web browser and browse the IP address "192.168.0.1." Enter the username "admin" and leave the password blank. Note that these are default values; both the user name and password can be changed. Click the "Setup" tab at the top of the screen, then click the "Wireless Settings" Scroll to the bottom of the screen and click the "Manual Wireless Network Setup" button. Place a check in the box labeled "Enable Wireless" and click "Save Settings."
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc If you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima D-Link Wireless Router D-Link routers use the connection from your Internet service provider to create a wireless network for the various Wi-Fi- enabled devices in your home or office. Once the router is installed, you can truly enjoy the portable capabilities of your laptop or other wireless device. D-Link routers have a straightforward installation process, despite the advanced technology behind wireless equipment. So there is no reason to wait around for a technician to help you install your wireless equipment.
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem. Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet. Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router. Your router will immediately begin distributing a wireless network with the "D-Link" network name. Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser. Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field. Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
Network D-Link wireless b> Type the router IP address, "192.168.0.1", into your Internet browser. Press "Enter" on your keyboard. Enter your username and password to log into the D-link configuration panel. By default, the username is "Admin" with a blank password field. To prevent outsiders from being able to access your D-link router's configuration panel, change the username and password to something more secure. This can be done by selecting "Tools" from the menu and selecting "Admin." Select "Administration Settings" and enter your new username and password. Save your changes by clicking "Apply." Enter the IP addresses for the computers you want to give access to your router. You can do this by clicking the "DHCP" link underneath the "Home" tab. Click "Apply" to save the IP addresses. Select the "Wireless" link underneath the "Home" tab. Enter a name in the "SSID" field to identify your wireless network. Choose "WPA" for your "Security" option. WPA will provide the highest level of security for your wireless network. Create a WPA password to access your wireless network. For maximum security, enter a combination of numbers, letters, and symbols. Store your password in a safe place in case you ever forget it. Click "Apply" to save your settings. Install a software firewall program on your computer to add an additional measure of security for your wireless network. A few of the popular firewall programs available are Norton Antivirus, McAfee and Zone Alarm.
Jan 28, 2013 | D-Link DIR-600L Wireless N150 Cloud Router
Installing dlink password into printer
The encryption password is in the D-Link's wireless settings.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 21, 2012 | D-Link DIR-615 Wireless Router
Forgotten password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 15, 2011 | D-Link DIR-615 Wireless Router
I can't change my wireless password because i can't access my drink account, i've tried admin and leaving the password blank but it says is wrong, any ideas?
Try admin, admin. If no success, go to D-link and download manual, press reset button on the router for 30 sec. And reset the settings, remember to change and record: system id, access password, wireless security, wireless password.
Oct 10, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do I reset the password to my D-link wireless router
Don't have specific knowledge of D-link routers, but generally, you want to a) find the default password for the system mgmt page at http://192.168.0.0, and then reset the router to the default settings by pressing the reset button on the back (?) of the router to reset the password to the default (and all other default settings too).
Oct 09, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do i install my WIRELESS G ROUTER without the cd
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
Sep 21, 2009 | D-Link DIR-300 Wireless Router
D-LINK ROUTER PASSWORD
hello... I have one problem,,I forget to password my router air plus G+. so, I want to reset my router,,how?
Oct 28, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link Wireless router
Assuming you ahve windows XP or a lower version of windows installed
Click on start >> RUN >> type CMD
In the command prompt box type IPCONFIG. You'll get the ip address and default gateway. Note the default gateway. Open Internet Explorer and type the default gateway in the address bar and hit enter. you'll be prompted for a user name and password. Check router documentation for a default login name and password. Browse through the option to set the password. Would be hepful if you give the operating system and router model name.
Aug 31, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
