Question about Nokia 5530 XpressMusic Smartphone
Whan I go to my web browser on my nokia 5530 and try t connect with wlan it says connection not available and it dosent connect. Any solution?
  • 70 Answers
First scan your wlan network then try to browse
Posted on Aug 28, 2010
How to i connect my nokia e5 to wifii
Hi there
Select Menu > Ctrl. panel > Connectivity > WLAN wiz..
The WLAN wizard helps you to connect to a wireless LAN (WLAN) and manage your WLAN connections.
If the search finds WLANs, to create an internet access point (IAP) for a connection and start the web browser using this IAP, select the connection and Start web browsing.
If you select a secured WLAN, you are asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
I also found the full manual in pdf format which you can download from here
http://nds1.webapps.microsoft.com/phones/files/guides/Nokia_E5-00_UG_en.pdf
Good luck
Nov 11, 2014 | Nokia E50
Nokia5530 expressmusic WLAN problem
*#62209526# - Shows MAC address of the WLAN adapter.This will be useful while connecting to internet through your phone's Wifi connection.
Jun 20, 2012 | Nokia 5530 XpressMusic Smartphone
How to connect to a home modem (wireless) ?
Theres two ways you can try:
1. - Push white button to open application screen.
- Look for settings, open it
- Theres WLAN / WiFi connectivity push it and wlan networks will pop up if available.
2. Open internet browser and it should say: "unable to connect" and you can push from there to settings.
Jun 09, 2011 | Nokia 5230 Cell Phone
I cannot connect my nokia c7 to the internet through wifi
Hi, pls verify below steps,
1.Whether WLAN switched on and has a good WLAN coveage. 2.Security settings on WLAN options
- Check the security modes (Open/WEP/WEP2 - this depends on your WLAN connection) - Check Security settings (Public shared Key settings)
3.You have to be a authorized user in WLAN network if it requires authentication login. 4.Open the browser on you mobile and select General->Connection->Always Ask, then it will prompt for the connection type, Select WLAN.
Thanks, Ramaly
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
I cant get internet on my n97 nokia phone so i want you to help me with that.
Hi
Check the priority of your internet connection access points under settings>connectivity>destinations. By default the WLAN gets higher priority. Therefore, when there is a known WLAN available, the phone will connect through it before any GPRS or 3G connection.
Also, there are some reports of conflict between the WLAN & GPRS/3G connection & the web browser gets this conflict & present the "Invalid server name". The solution of this is to close your browser & restart your phone. Also, removing your WLAN, GPRS, or 3G setting & redefining them may help.
Good luck.
Aug 26, 2010 | Nokia N97 Cell Phone
My nokia 5530 is not connecting to GPRS it is showing msg as packet data not availiable.
If your phone is not connecting to GPRS it means that you don't have a GPRS setting available. You need to have it set up. You need to contact your mobile network provider to request for these settings.
Aug 26, 2010 | Nokia 5530 XpressMusic Smartphone
How to connect my nokia n95 to wifi
Sir,Your required Wifi Connection to access internet OR you can access internet using GPRS service Nokia N95 you.For-you require Wifi router then your mobile will detect that wifi connection and you will be able to access internet on your mobile phone.
Dec 10, 2009 | Nokia N95 Cellular Phone
Nokia 9500 get restart when click Internet Broser / WLAN setting
Your firmware is ANCIENT. If you have installed Nokia PC suite in your PC connect your (fully charged) phone and click on Software update. If don't have it, then go to Nokia web and download it. YOU NEED FIRMWARE UPDATE.
Oct 16, 2009 | Nokia 9500 Communicator
Web Browser
its not you browser it a connection problem ...if you are using net through GPRS then once again get the GPRS settings for your cellphone.. or if it is wifi then check the connection settings properly..
Jul 04, 2009 | Nokia N81
Nokia 5530 XpressMusic Smartphone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
