Question about Panasonic CT-27SX11 27" TV
CT-36HX42F The other day it stopped completly. No power at all! Is there a reset button on these? We are stumped...thanks Jennifer
I had the same problem. Sometimes the processor gets overheated, particularly when dealing with high definition signals. Unplug the television from the power strip or wall outlet and it should reset everything. When you plug it back in it should work. Not a long-term solution, I know, but it will get your TV working again.
Posted on Jan 10, 2009
How to reset canon mg2240 ink absorber
Follow these mentioned steps after entering in to service mode:
1. Turn off the printer
2. Press and hold the button stop/reset
3. Without releasing the button stop/reset, press the power button (ON/OFF)
3. Release the button to stop/reset and pressed the power button.
4. Without releasing the power button press the button 5 times stop/reset.
5. When completed, the display of the printer any information should not appear, and release the power button.
In case, if this is not work for you, recommend to call me at +1 (844) 355-5111 (toll-free) number.
Thanks
John
Apr 13, 2017 | Canon Office Equipment & Supplies
Does the Cannon MX310 printer have a memory chip for all it has printed? I am getting another printer and I want to know if my personal information is in the printer.
It retains 50 faxes in memory. You can reset the printer to clear it .....
Instructions
    • 1
      Turn off the power to your Canon MX310 printer. Hold the "Stop/Reset" button for five seconds then press and hold the "Power" button.
    • 2
      Release the "Stop/Reset" button. Press and release the "Stop/Reset" button twice, then release the "Power" button. Watch for the power light to illuminate steady green, then press and release the "Stop/Reset" button. Count to three then repeat the process until you have pressed the "Stop/Reset" button three times.
    • 3
      Press the "Power" button when the indicator on the power light illuminates orange. Open the printer cover, lift the retaining tab on the ink cartridges and remove the cartridges. Wait 30 seconds, reinstall the cartridges and lower the cover.
    • 4
      Press the "Power" button to turn off the printer. Once the power turns off completely, press the "Power" button again to turn the printer back on to complete the reset process.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 05, 2011 | Canon PIXMA MX310 All-In-One Printer
Panasonic ct-34wx54. I cant remove the closed captions from the screen. When i go to the menu and try to shut it off the on and off modes are "grayed out" and cant be highlighted. Reset with...
Try pressing the volume down button on the T.V. and the info button on the remote. Do this for at least 5 seconds and it will reset the T.V.
Mar 16, 2011 | Panasonic CT-34WX54 34" TV
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
TV Won't Turn On
there is no reset button - the main fuse has probably blown and needs replacing (6.3A 250 V)
Dec 26, 2008 | Panasonic CT-32HX42 32" TV
Panasonic TV
Good mornig,
Actually, I was helping my son-in-law ... I never got an answer here, and he called a repairman, which fixed the problem, but cost him approximately $300.
Jul 08, 2008 | Panasonic CT-36HL43 36" TV
Panasonic CT-27SX11 27" TV Logo
124 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
