Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
How do i replace the front door washer gasket on a bosch nexxt 500?
  • Bosch Master
  • 17,129 Answers
The gasket is needing a change becasue it is worned out. So I guess that you have got the same model gasket to be replaced.
the gasket has to go into the slot to fall into place and make the sealing water tight.
So remove off the fittings and remove the gasket out of the slot.Now replace inthe same format , push the head of gasket into the slot using good pressure and then do the fitting of the gasket to seal into place. close door and cconfirm the fitting.
Switch on and see for any leak before your first wash.
Posted on Aug 28, 2010
  • Donald DCruz
    Donald DCruz Aug 28, 2010
    Use of some rubber based adhesive can be used if there is any leak.
Replace door seal loader washing
This video will show you how to change the door seal on your bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My Nexxt Washer has a black residue on the front gasket.
The black is not algae it is mold. The only way to fix it is to replace the gasket/seal.
Feb 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
We have mildew in the rubber gasket behind the front door
use a good mildew cleaner on gasket the gasket gets wet from when clothes are taken out and drip on gasket mildew grows on damp/warm surfaces
Sep 26, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Wire off around door
This video will show you how to change a door seal on this Bosch front loader washing machine and the best way to get wier back on te door.
we have al bosch repairs in our channel
May 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Gasget came off the washer and i can't get it back on
I have the perfect solution the placing of the Retaining Spring back on the Bosch Nexxt 500 Door Gasket. It only took me only 5 Minutes after fighting with it for hours and getting nowhere. What I did was purchase a set of 12 inch hemostats (long Clamping Pliers). The ends of the Hemostats I wrapped both of the jaws with Electrical tape to prevent the Spring on the retainer from sliding up the jaws of the hemostat. When the ends of the retainer are placed on the ends of the jaws and the hemostat opened the spring is stretched. I found that If you use your knee to hold the hemostat open while placing the retainer in the groove of the gasket you can slowly release the springs and set the retainer back into the gasket without the gasket pulling off the tabs.
Mar 01, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Replace door gasket
It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
Plz rate this solution .
Thanks.
Dec 19, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
354 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
