Question about Epson Stylus CX5400 All-In-One InkJet Printer
Workforce 315 had a paper jamb, cleared jamb but now have a flashing on switch and a flashing auto answer/space light. Manual only says turn off and back on.
  • 3 Answers
SOURCE: Paper light says on.. wont reset after jam is cleared
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Posted on Apr 03, 2008
Roop1980
  • 228 Answers
SOURCE: All lights flashing after clearing a paper jamb
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Posted on Apr 14, 2009
Icebassman 5
  • 57 Answers
SOURCE: epson workforce 600 error message; please clear document feeder
Hi there.
Still there might be traces of dust or small paperpiece somewhere.
Iceman.
Posted on Nov 10, 2009
  • 53 Answers
SOURCE: a22 paper jamb won't clear
reboot the machine:) its a definite fix
Posted on Nov 30, 2009
podita
  • 324 Answers
SOURCE: shows paper jamb - when there is no paper jamb-
open the printer up power down, and restart it it should clear the memory
Posted on Mar 24, 2010
ADF error-says to clear paper jam and restart there is no paper jam.
If you are 100% positive there is no left over paper jammed, then most likely your paper feeder needs to be lubricated.
Mar 30, 2015 | Epson WorkForce 545 Wireless All-In-One...
Epson workforce 1100 flashing lights
please help me to find epson office me 1100 resseter
Jun 13, 2012 | Epson Workforce 1100 InkJet Plotter...
Epson workforce 633 warning paper jam when no paper jammed power wifi and fax auto lights flashing can not get to menu
I had success by turning the printer off and on again with the top pieces up (as if changing the ink). I found this trick also works when I have a scanner error that won't go away. Good luck!
Apr 23, 2012 | Epson WorkForce 633 InkJet Printer
I have an unresolved paper jam, i have the epson workforce 520.
If you do not have an actual paper jam (no paper is stuck in it), then you merely need to clean the inside as there may be a small piece or some light debris (dirt) that is triggering the sensor. You can do this by using an air can and blowing out as much of the inside on the rollers. Try to print something, or run a piece of paper through (manually if possible) to get the rollers to roll over and use the air can again.
Also, if you have the manual - try and locate a "reset" button. If there is not one - turn the printer on - press and hold the on/off switch until you see all the lights on the printer come on and/or start flashing. Once this happens, press the on/off button once - until the printer shuts off. Restart the printer again and see if the indicator for paper jam comes on again.
Please let me know if you need further assistance.
carsandcomps
Aug 26, 2011 | Epson Workforce 520 Printer
My samsung clp 315 printer, lights RED and AMBER together when i switch it on.
my samsung clp 315 Red light blinking & in printing a Horizantal line is came in centre of the paper
Jun 22, 2011 | Samsung CLP 315 Laser Printer
Why is yellow light blinking on top of unit?
Per the DS1 manual the yellow light relates to the SafeSense feature. A toggle switch under the deck is the SafeSense override switch. The override switch deactivates the SafeSense feature so that you may clear a paper jam. When the switch is in the override (left) position, the SafeSense yellow light will flash and the SafeSense feature will not function. Once the paper is cleared, reset the SafeSense override switch to the right position. The SafeSense yellow light turns on when you touch or are too close to the paper insert opening.
Jan 18, 2011 | Fellowes DS-1 Shredder
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Cleared a paper jam but E then 2 and alarm still flashing
Error code 2 is mean no paper present. Just put paper at the Auto Sheet Feeder.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
