I need wire diagram for trane a/c unit model2ttr1048a1000aa
4 Suggested Answers
  • 116 Answers
SOURCE: Need low voltage wiring diagram for condenser
look on the indoor unit and see what they do you hav common from trans former yellow for compressor white for elect heat then reversing valve usually orange green for fan on the out door unit board you can tell what is common and what is for heat
Posted on May 09, 2009
  • 234 Answers
SOURCE: hello i want to conect a trane condensator
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Posted on Jan 27, 2010
  • 26 Answers
SOURCE: need wiring diagram for trane condensor
go to the trane site you'll find help their
Posted on May 06, 2010
I need a wiring diagram for a trane model #BWC024C1000A
Request the wiring diagram directly from Trane.
May 18, 2017 | Heating & Cooling
Wiring diagram for a sfhf trane wiring diagram
i need a wiring diagram for trane weathertron heat pump.
Jul 03, 2012 | Heating & Cooling
Wiring diagram for Bay SEN SOL 9-B, Need to know what the numbers control on the thermostat, lost manual with wiring diagram.
trane used dc t-stat for a while with a sensor in line.It was designed to run off of the sensor in the event that the t-stat failed.If your model is like that get a dc-ac converter board and you can use any 24vac t-stat.Will take alot of problems away because the dc will pick up residual current if using unshielded wiring.
Mar 05, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Jan 27, 2010 | Heating & Cooling
I need a Trane air handler twv030b140a1 wiring diagram
i cant attach the PDF file to this so send me an email to mac5932002@yahoo.com and i will send it to ya
Sep 13, 2009 | Heating & Cooling
May 08, 2009 | Heating & Cooling
Need wire diagram for GE electric furnace
Usually the older GE's are straight forward and any generic wire diagram will help you out. If its newer and a Trane made unit try A Trane dealer.
Mar 27, 2009 | GE Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
