Question about Kenmore Refrigerators
I have an Kenmore elite with the freezer at the bottom and the upper refrigerator does not get cold. The temperature is 71 degrees
    President:
  • 2,702 Answers
You need to fit a new thermostat to the refrigerator,,,,,
Posted on Aug 28, 2010
Can't raise temperature
35-37'Celsius is very warm. room temperature is around 19-23'c idealy
Can you post me the model number so I can get the user manual with the instructions on how to adjust the temperature?
Aug 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My Kenmore Elite 25' Bottom Freezer Refrigerator, the lower freezer portion is working mainting a -3 degrees but this morning the upper refrigerator portion is not, what would be some likely problems to...
I guess you are talking fahrenheit temperature?
This is ok for the freezer.
The problem could be;
\ ducting blocked restricting air flow
\ evaporator fan not working
\ ice build up on the evaporator blocking air flow
You will need to get a technician to look at this problem for you
Mar 25, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
