Question about LG Chocolate 3 Cell Phone
Lg chocolate touch screen not working - LG Chocolate 3 Cell Phone
I have a LG Chocolate BL 40. It fell down and cracked its display screen from several loactions. So I got a the cracked display screen replaced with a new one. All seems to be working fine except that when the call comes the answer button which used to display as green gets greyed out and does not lets you answer the call. I have tried upgrading the software as well as a factory reset bit it has not helped. C
Can somebody advise how/if it can be fixed?
Posted on Jun 12, 2011
SOURCE: My LG chocolate touch 8575 touch screen is frozen
My phone has done this many times! I have an LG versa, which is from verizon. This is what I did. I took the battery out, and left it off for three days. Turn it back on, and it should work!
Posted on Apr 24, 2010
SOURCE: LG chocolate touch screen goes black once I call
I had the same, or a very similar problem. What happened with mine, was the sensor on the upper right corner of the phone was getting blocked. It is supposed to sense when you have the phone next to your face and then it will darken the screen, Mine had plastic that was obstructing it. Hope this helps.
Posted on May 16, 2010
SOURCE: my L.G. chocolate touch screen is not working righ...
mine is doing the exact same thing.. i have no idea how to fix it either. let me know if you figure something out!
Posted on May 29, 2010
  • 713 Answers
SOURCE: the screen on my LG
It can be deduced from your problem that there is no longer a contact between the inner touch pad and the outer touch screen,hence the touch is no longer responding.
The solution is to take apart the phone and replace the touch screen,
Here is a detailed disassmbly to assist you in replacing the touch screen;
1.Remove your battery, sim and memory card. Six screws need to be removed. Two at the top of the phone are covered by plastic stickers which will peel off.
2.Run something like a credit card around the join of the battery compartment to release it from the rest of the phone.
3. Two ribbon connectors need to be disconnected. Each one attaches like a plug and socket. Just lever them up to unplug. You'll then be able to lift the two green circuit boards away from the rest of the phone.
4. Remove the six screws you can see and then you can remove the next layer of the phone.
5.Run your plastic tool along the join of the front cover in order to release it.
6.Two ribbon connectors need to be disconnected. Again, each one attaches like a plug and socket. Just lever them up to unplug.
7.Lever the camera out with your plastic tool. It is stuck down lightly with double sided tape and should come away easily.
8.Lift the screen away from the front cover. It should be loose. Next peel away the big black piece of sticky tape. Now slide your plastic tool under the LCD screen to separate it from the green circuit board. It will be stuck down with double sided tape. Once the double sided tape has been released, pull the screen in the upward direction.
9.You should now have the small LCD screen removed.
Thanks and take care
Posted on Aug 05, 2010
  • 17 Answers
SOURCE: my LG-VX8575 chocolate touch screen
check your belt of phone and touch plate's soldering.Some times touch plate soldering is lose or touch plate's belt might be broken so change it.
If problem still remains take your mobile to the mobile shop for flashing........
Posted on May 19, 2011
My lg chocolate touch's screen went half black
your screen has broken and LCD also has broken that's why your half screen is working and half is black. you have to change your screen and then use your phone again like before
May 17, 2017 | LG Cell Phones
My l.g. Chocolate touch screen is not working right....i can't touch it or if i do it goes to something else
May 20, 2010 | Cell Phones
My lg vx110000 touch screen stopped working after i sprayed windex on a cloth and cleaned the touch screen.
i did this twice with my chocolate touch and mine also stopped working /: the prollem is you had a scratch in your phone, or it got into one of the cracks, and jacked things up in there.i wouldnt do that anymore :|
Apr 11, 2010 | LG enV Touch VX11000 Cell Phone
Apr 06, 2010 | LG CHOCOLATE VX8500 Cellular Phone
LG chocolate touch screen cracked
Hi arielautumn,
The only solution is get the entire screen repaired,,, then only the screen view will be clear,,,,,,
good luck with your fix,,,
have a nice day,,
Regards
Arul
Mar 06, 2010 | LG Cell Phones
Touch buttions dont work
Either the touch buttons got wet, or you got the Chocolate of Doom. There are many LG Chocolates being sold to people and the touch sensors aren't lined up correctly with the buttons and they eventually fall out of place. I suggest replacing your phone with a different phone. DO NOT GET ANOTHER CHOCOLATE unless you want to risk this happening again. Hope this helps!!!!
May 14, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Hey i have a question about my chocolate phone
Your phone needs to be replaced. The touch pad simply just went out on you.
Nov 28, 2007 | LG CHOCOLATE VX8500 Cellular Phone
The touch screen of my lg chocolate vx8500g is not working
return to lg for fast free replacement they know the problem and will next day to your hands...
Nov 20, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG Chocolate 3  Cell Phone Logo
1,484 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
