Question about O2 Xda Atom
Reset to factory default
Hi.. my o2 can't start-up, i tried to do clean boot but its take too long and never ending, please advise
I have been using this phone for a little over a week, and am having a problem with
cprog.exe. After most phone calls, I have a message from windows saying that there was a
problem with cprog.exe, and it then sends an error report. I though that the phone might be
a little buggy at first, but this problem has continued and is very frequent. Is anyone else
having this problem?
my mail: briden@kantipur.com.np
model Xda Atom
Posted on May 22, 2008
Need to reset factory settings to wipe laptop clean but dont have a disc
hi
there is two ways to do it.
Laptop Recovery Instructions
If you cant boot into windows
1. Power on the machine
2. At the white ACER BIOS screen, hold the "Alt" key and press the "F10" key
simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click "Restore to Factory Default Settings"
4. Click "OK" to continue
5. From here, the eRecovery process will update all the data on the C: drive
and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit
If you can boot into windows
Click "START"
All Programs
Acer/ Packard Bell/ E-machine recovery
Select "Recovery management"
Click "Restore"
Click "Fully restore to factory default"
NB: This process takes about 15 to 20 min
Jun 15, 2011 | Acer Computers & Internet
I have an acer aspire 5310 laptop and want to restore to factory settings can you help me please
Hi Friend, Please try the following steps:
Instructions
Things You'll Need:
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
NOTE: Please make sure to backup all the data from the system before resetting it to factory settings
Please let me know if these steps were of any help
Dec 09, 2010 | Acer Computers>Laptops Aspire 5610-2013 PC...
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
How do I restore my acer to orginial factory settings?
Hi!
Before restoring your machine to factory default please make sure that you mback up all your program and files to any external device.
Please follow the step by step procedure to restore your machine to factory default.
1. Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
2. Detach any external hardware such as an external hard drive or printer.
3. Press the Power button to boot your Acer laptop.
4. Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
5. Select "Restore System from factory default" in the Acer eRecovery Management window.
6.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
7. Click "OK" in the notice window to proceed with resetting your Acer laptop.
8. Wait while your Acer laptop is reset to factory settings.
Should you have any other questions please just leave a comment.
Cheers~
Sep 09, 2010 | Computers & Internet
Need to reset my acer computer to factory settings.
Hi! Try system restore first and check if that will remove the virus but if not then you can reset the machine to factory defaults by pressing ALT+F10 during start up or when the acer logo appears on your screen.Follow the prompts and you should be able to reset the computer to factory image.Make sure you back up important files because it will wipe the system clean.hope this helps...
May 29, 2010 | Acer Aspireā„¢ T180 PC Desktop
O2 xda formatting
Quite possible the upgrade failed and has corrupted something.
You will need to find out how to perform a Cold reset as this should return it back to factory defaults.
See here for some assistance.
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
Apr 24, 2008 | O2 Xda IIs Pocket PC
Hard Reset
To do a Hard Factory Reset:
Simultaneously press the Suspend/Resume (END) button whilst pressing the stylus tip into the reset opening.
end_button.jpg reset_button.jpg Keep them held until the screen comes back on. Then release the buttons
You will get the Boot options:
  • CLEAN REGISTRY - This resets the device to factory settings, losing applications but keeps the data intact.
  • FACTORY DEFAULTS - This completely wipes everything and resets the device back to it's factory defaults.
  • SKIP
    Try Clean Registry first.
  • Jan 13, 2008 | Fujitsu Siemens Pocket LOOX T830...
    My o2 celphone won't turn on
    O2 XDA Atom / O2 XDA Atom Pure / HP rw6828:
    To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device.
    *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
    i hope it will help your prob.
    Dec 01, 2007 | O2 XDA Mini S Smartphone
    Restoring acer aspire to its factory settings
    From Acer customer support:
    1 Ensure all Data is backed up, all data will be deleted.
    2 Restart machine
    3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
    4 Please wait a moment until prompted, -How would you like to restore?-
    5 Please select –Restore system to factory default-
    6 Enter your defined password or enter six zeros ‘000000’
    7 Click ok
    8 Please wait until process completed, this will take 45min – 1hour
    Oct 03, 2007 | Acer Aspire 5100 Notebook
    Computers & Internet Logo
    175 people viewed this question
    Top O2 Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    zurysk8
    Level 1 Expert
    Martin Murray
    Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
