Local Area Connection Disable Randomly Itself
Dear Expert,
There is an issue with some PC's NIC in our workstation that LAN gets disable itself and you have to go physically to the users computer to enable it.
I have tried some solution like unchecking the power option from power management in NIC properties and other stuff like this.... but no result..
Please help out!!!!
Thanks,
Aryan
  • Anonymous Mar 13, 2014
    while looking for my gmail forum -(devankanbasu1@gmail.com) i face difficulties like pop-up blocked,cookies disabled option coming
    Scholar:
  • 115 Answers
You have to check the Bios CMOS setup in that enable the network boot from the client and check it and change the all other system on your client.
Posted on May 07, 2008
Disable NIC in bios
So go into set-up menu and disable.
Apr 30, 2014 | Dell Precisions Workstations T3610 BTX...
Tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
How can I configure the Internet Access Policy under the Access Restrictions tab so that only certain workstations/users (connected to my network through the wired and wireless options) will have access to...
Hi Wilson,
You can block Internet access by specifying MAC addresses of PCs you want blocked. The MAC address is the physical address of the network card in the PC.
Please page 54 for instructions on setting up this policy.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000000300.pdf
To locate the mac address of a PC.
click Start, then Run, then type cmd in the text box.)
Type in ipconfig/all in the Command Prompt Windows. Review the output.
The 12-digit Physical Address is the same as MAC address
Sep 02, 2011 | Linksys Wireless-G WRT54G Router
My server has 2 NIC one of them connected to the router (ISP) and one of them is connected to the LAN.But DHCP and DNS working but there is no internet to the Host and also the server itself.when i...
This is more a configuration error. Depending on how you have your DHCP setup, you may need to adjust it's setting. No mention of what os you are using but if you set your DHCP to give IP addresses only to the LAN, set the ISP NIC address to receive its ip from the ISP provider, you should be able to get Internet access to your server and the LAN.
If you have done so, use the server os to setup your Internet connection. Answer a few questions about how you connect to the Net and the os will do most of the configuration for you.
Good Luck
C2Solutions
Jan 24, 2011 | Dell PowerEdge 1800 Server
Nic card disabled by itself in a random basis, I need to re-enable it manually.
KINDLY REINSTALL THE LAN DRIVER OR UPDATE DRIVER OF NETWORK ADAPTOR (MY COMPUTER->MANAGE->DEVICE MANAGER)
Feb 18, 2010 | Dell OptiPlex 360 Desktop Computer
When i turn it on i am asked to select one of two choices of operating systems(windows NT workstation version 4.0, or windows workstation version 4.0[VGA mode]) which one should i choose? whichever one i...
Hello!
Yours problem can be system, or hardware.
First try in bios disable integrated pheriperals, like modem, lan, sound, and try boot.
If the trouble still here, try install new system with full format hard drive.
If you still have a problem, you have some hardware problem,something like procesor heathing.
Nov 02, 2009 | Compaq Armada 1700 Notebook
Some of my workstation immediately disconnects fron internet
That sounds (apart from a really heavy load on the little router) very much like you are running out of DHCP addresses.
Are your computers set to static or DHCP?
Are they connected via cable or wireless?
What is your DHCP range?
What is your lease time?
If the computers get rebooted i.e. 6 times per day and your default lease time is 1 day, that means that only one computer is blocking already 6 IP addresses per day. 33 computers therefore are blocking 198 addresses, which is almost your entire spectrum from 192.168.1.2 - 192.168.1.254.
So either set them to static IP or shorten the lease time.
Jul 04, 2009 | Computers & Internet
LAN automatically disconnects while downloading and starts working only after disabling and again enabling the local area connection
With this issue it could be the Hardware / Software compatibility. The first thing to do is ensure the latest drivers are installed or the NIC. If the latest drivers are installed I would recommend replacing the NIC. They are less than $30 and they come with great drivers, and if the old NIC is onboard it would be advantageous to get it off the Motherboard. It would be best to open up the computer before you run out to get the new NIC and makesure the motherboard can support a PCI card. This card slips into the White slot that is about 3 inches long. If you have a White slot that is about 1 inch long this PCI card will not fit into it the card you will need is a PCI Express x1 NIC. The rest of the information you will need is provided by the NIC Manufacturer.
Mar 30, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
LAN Problems
Goto system BIOS and turn it on, u may have turned it off accidentally
May 08, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Open Questions:
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
