Question about Sanyo DRW-1000 DVD Recorder/VCR
Taping to VCR from Camcorder
Can anyone enlighten me as to how to tape from my camcorder onto the VCR. I have read the manual and set everything up as suggested, but think maybe I am coming unstuck with the channel selection. Should it be on AV to record or is there another channel? I really have no idea? Thanks...  :)
    Brigadier General:
  • 6,966 Answers
If the camera is attached to the VCR using the yellow, red & white RCA cables or the S-Video cable, then the VCR has to be set to AV or Video IN.
On the otherhand, if the VCR is connected through the RF OUT to the TV's ANT/Cable/RF IN, then the TV has to be set at either Channel 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 07, 2008
How to play tapes not recorded by Sony Handycam DCR-TRV130 Digital-8 Digital Camcorder
It is my understanding that the camera won't playback those formats, timecode or not. There are VCR type units for the HI8 and other formats. They should be cheap on eBay now...
Nov 18, 2012 | Sony Handycam DCR-TRV130 Digital Camcorder
My camcorder is spoilt and I am left with many mini DV tapes which I cannot download to the PC without the camcorder. Is there any solution for this?
since it is in digital format a standered VCR wont read them the hi-8 tapes have a bigger VCR tape you can put the hi-8 tape in and insert that into a VCR but the hi-8 is an analog tape is digital "DV = Digital Video" so a standard VCR wont read them the only way is to borrow a friends Mini-DV camera and copy all your tapes over. they do make a Mini-DV player but even the cheap ones cost more than a new camcorder would! Sorry to hear about your camcorder I hope this helps
Aug 12, 2010 | Panasonic PV-GS400 Mini DV Digital...
Pink lines when i play back my tapes on my canon zr500
Hopefull your not going through the tv and then to your dvd recorder
transfer should go straight from your camera to the dvd recorder.
you may also want to but a head cleaner for a mini dv camcorder,run it twice and try recoding again.If that doesnt work,you may have a problem with the heads inside of the camera.If thats the case,it would need to go to canon or an authorized service center.
Feb 01, 2010 | Canon ZR500 Mini DV Digital Camcorder
Dubbing from vcr tape onto panasonic NV-GS200
its not posible, because the camcorder doesn't have inputs it only has outputs
Aug 13, 2009 | Panasonic NV-GS200 Mini DV Digital...
Dub a tape that is playing through my camcorder on TV
A vcr or dvd-recorder only reads the input signal. It does not care where it is coming from, only that it is there. You would have to run it through the vcr or dvdr for it to read the signal, or copy it to your computer and burn it to dvd.
May 27, 2009 | Sony Handycam DCR-IP7E Micro Digital...
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Need manual for "line" setting
I have this same unit and it looks like the answer is on page 14
of the manual. If you don't have the manual and want a copy of
page 14 e-mail me at and put PLEASE SEND PAGE 14 OF MANUAL in the subject line of
the e-mail. Capitalize the subject line so that it gets my
Jan 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Problem taping on vcr from panasonic nv-gs50
if you are using rca cables let the cam playing something you recorded and try find the channel on vcr(on its tuner).it would be helpfull if you post a picture of your cord
Nov 03, 2007 | Panasonic NV-GS50 Mini DV Digital...
Transferring camcorder tapes to VHS
It depends on what speed these tapes were first recorded on. Maybe the camcorder your trying to use to play them back do not support this tape speed I have seen this in the past. Are these 8-MM or VHS-C tapes.. Also the tapes that were recored, maybe tyhere was something wrong with the tape path and was slightly out of alighnment. I had once a Sony 8-MM camcorder and tapes a lot of stuff and then gave them to someone to watch and they would not play. I tryed the tapes again in my camcorder and they worked great. I got a test tape and tryed it in my camcorder and it turned out the tape path alighnment was off, so i had to rerecord everything I had from one camcorder to DVD so i could fix my camcorder. Good Luck
Mar 26, 2007 | Hitachi VME545 Camcorder
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Sep 06, 2005 | RCA CC-432 Camcorder
Sanyo DRW-1000 DVD Recorder/VCR Logo
44 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
