Question about Maytag 30" Self-Cleaning Freestanding Gas Range - White
CONTROL PANEL DOES NOT WORK MODEL NUMBER IS CRE9400CCE
  • 530 Answers
Does no keys respond? or is it just one function like bake? turn the power off to oven and take the back panel off and inspect all the wires going into the board. are there any codes?
your control board part number is 400580 and you can go to repairclinic.com to get it.
let me know if you need any more help
also let me know if it is just one function that doesn't work. if for example bake doesn't work but broil does you might have a different issue
Posted on Aug 28, 2010
Can't read oven temp on control board.
Hello;
My name is Peter. I am a retire field service appliance technician.
The model numbers you provided are for wall space heaters.
Open the oven door the model number should be on a label on the face of the oven or on the side of the door.
Your control panel has red lights on it. Sometimes they burn out and you can not read the numbers.
Find the model number and go into the following website. Record the control panel part number. Search the web for this part number.
I recently, purchased a remanufactured oven control board for $45.00, when Sears wanted $256.00.
Make sure you ground yourself before you touch the control board, by touching something metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Mae sure you turn the power off to your range before you start the work.
Feb 28, 2016 | Kenmore 95012 / 95014 Electric Kitchen...
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 24, 2013 | Dishwashers
G 2582 scvi
make this test and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Samsung DMT - 400 delicate light blinking
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Regency problems
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
Maytag 30" Self-Cleaning Freestanding Gas Range - White Logo
146 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
