Question about Sport & Outdoor - Others
On 2006 EZGO electric golf cart, 36 volt. Cart intermittently goes very very slow. Sometimes, after backing up then will go normal 19 MPH. Turn it off and the goes slow again. facts - batteries tested and show 6 volts each and full set tests at 36v. Cart never had this problem until ran out of power and was towed about 1000 yards. I was told by by the person towing the cart that he put the control switch from Run to Tow. Any ideas what the problem could be?
    Master:
  • 487 Answers
He may not have known to put it in tow mode and doesn't want to get blamed for damage to transmission towing it in wrong gear.
Posted on Jun 11, 2017
  • 6 Answers
SOURCE: electric golf cart, mash the pedal won't move
you have a broken belt .
Posted on Jun 03, 2009
  • 85 Answers
SOURCE: I just bought new batteries for my Club Cart Golf
You have the motor hooked up in reverse, you need to switch the two wires leading to the motor in order to fix it.
Posted on Oct 04, 2009
  • 174 Answers
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Posted on Nov 12, 2009
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
  • 34 Answers
SOURCE: batteries run out of power too quick, what is my problem
The voltage should be above 37 volts if you have 6 volt batteries. This must be measured under load. A simple voltage check is useless. If the batteries are over 6 years old, they are probably in need of replacement.
Posted on Apr 21, 2010
  • 63 Answers
SOURCE: I NEED A WIRING DIAGRAM
what does a wiring diagram have to do with a cup holder mount? You might want to change how your question is posted to get people better able to help you!
Posted on Jul 09, 2010
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
How do I connect 36 volt battery charger to electic golf cart?
Maybe you have an Ezgo cart? Black is negative, white is positive, and the small red wire is connected to the white inside the charger receptacle.
Sep 04, 2015 | Golf
I have a ezgo 36 it's got power but runs slow, batteries are full
Does your controller have a 6 pin connector on the top? If it does then only 4 pins are wired. Pins 1 and 2 are the throttle, pin 3 is reverse and pin 4 activates the controller.
First I would check the batteries under load. then check voltage from main negative battery post to pins 3 and 4. Should get approx. 15 volts going to the ITS throttle and other pin should get 5 volts at full throttle. If you get no voltage at either pin then probably a bad controller. Go to buggiesgonewild.com and search for wiring diagrams, they have a few for download.
Aug 14, 2015 | EZGO TXT Golf Cart Golf
How to troubleshooting sylnoid on 36 volt ezgo golf cart ?
goto buggies gone wild.com there are several forms that share this information on how to check a solenoid. You can also call golf cart kings in Austin Texas. They will tell you exactly how to check the solenoid. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Aug 31, 2014 | Golf
36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Apr 09, 2010 | 1993 Acura Vigor
Sport & Outdoor - Others Logo
956 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
