Question about Dishwashers
Hello. when I turn dishwasher on - on any programme - all I hear is the sucking noise of the machine draining. No programme will start.
  • 530 Answers
Sounds like you either have a bosch and or a LG. is this right? if so you probably have a leak under the dishwasher. and that is why it keeps draining. it is a feature designed so it doesn't flood your floor. you can take the kick panel off and stick your hand in the pan to feel for moisture.
Posted on Aug 28, 2010
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Noise Drain Motor? No Cloged
The Bosch units do have a little noisier drain pump than most other units, so if you don't hear a grinding sound it probably isn't something you would worry about, BUT if it is grinding, then it is a sign that either something got sucked into the pump or that the pump is starting to fail.
Jun 09, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Dishwasher will not run. Air Dry/Lock on light blinks and unable to turn off even if held for 4 seconds. If you press Start, "Quick Rinse" light comes on and blinks along with the Air Dry Light....
Sound like you might have a fallty drain pump. When you turn the power off and started again, did you hear noise of pump draining the leftover water. If not , then you have a pump problem. Need a service man. Good luck !
Feb 11, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the...
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Our Indesit dishwasher D1620 is not draining at the end of the programme. I have checked the hose its not kinked and there is nothing blocking the drain point. Any ideas what we can do?
When you put the dishwasher on for a new cycle you should hear the drain pump operating for a short while before it allows any water to enter the machine.If all you can hear is a buzzing noise then it is probable that something is stuck in the drain pump or the pump is faulty.If this is the case then you will need to access the drain pump through the removal of the side panel.
Hope this helped.
Jun 13, 2010 | Dishwashers
Homark dishwasher programs; ( Italian ?? )
just turn the timer around slowly and you will hear it start to drain
Dec 11, 2009 | Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Kitchenaid dishwasher sucking noise when ON
the sucking noise is the water valve, opening but it doesn't not sound it getting any water in. have the water valve replaced.
do you get any error messages on the display?
Sep 13, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Tecnik dishwasher tkd795/3
your machine has flooded and has trippedthe flood switch in the base of machine which turns on the pump to drain and that is the noise you hear
you will need to find cause of problem which is possible leak in machine
Mar 21, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
Owen Barnes
