I cant identify the prolem
im trying to fix a my pc that always keeps on rebooting... im using xp and by the time the windows display appears, it reboots automatically. i already tried replacing power supply, processor(even tried it with other pc), i checked the board for swelling capacitors and i also did putting silicon paste on the processors heatsink.. still cant find the problem. i just noticed that everytime i turn it on, it automatically displays the bios setup on the cpu speed even without pressing the del button.
can u help me with this problem?
  • 2,712 Answers
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
Posted on May 07, 2008
Keeps on reboot windows startup after format
Did you tried to change to compatibility mode in BIOS? if not yet, you can try it.
Dec 18, 2017 | Dell Vostro 1320 Laptop Computer (Intel...
Eee PC 1800HA can't go through windows xp installation
You have a "Driver Issue", generally a "Display Driver" but not always, what you need to do is start PC in "Safe Mode" Press F8 at turn-on, and then remove the display adapter from device manager and reboot, windows will then install a"Generic" driver and ya should be able to get to desktop to get the correct driver, and install. Sometimes it is faulty components too. But it seems ya may be past this point seeing as ya tried to re-install XP on it again... not the best way to handle it, but of course ya didn't know that.
However since ya have tried a setup ya may be in a bit of trouble. I think maybe ya only option is to Format the drive... and totally reinstall Windows XP. (Or ya just gonna have endless trouble). Use the DVD that came with ya PC and reinstall it.
Jan 24, 2010 | ASUS Eee PC 1000HE Netbook
Dvd on pc wouldnt work bough roxio supposed to fix didnt do a thing cant even find it im no comp.whiz cineplayer dvd decoder pk windows media player keeps saying no disc -dvd busy dvd player will play...
For all Windows (XP, Vista, 7):
Click the FixIt button, when prompted select RUN.
When the tool is done, reboot.
If the problem is with Windows, this will solve it for sure. Otherwise your drive may be dead or the power disconnected.
Jan 01, 2010 | Computers & Internet
Computer Keeps RESTARTING when ATI video driver installed
weve got the same prob.i also try what you did on your pc..but nothing happen but when i put a new graphic card it fix everything..try a new graphic card,
Dec 13, 2009 | ATI RADEON Graphic Card
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that...
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
May 08, 2009 | Microsoft Windows XP Professional for PC
Display blanks after installing drivers
Try the final AMD Display Driver (version 8.31) downloaded directly from AMD for the Radeon 9250 series running in XP. It will be several years more recent than any provided in Windows XP (by Microsoft), and may just fix your problem. The fact something causes XP to identify your Radeon 9250 as a 9200 Pro shows that something is not right. You might also want to launch Device Manager, use the option to show hidden devices, and delete any "ghost" video cards. I suspect a 9200 Pro may be a ghost, which could be causing problems.
Sep 13, 2017 | GeCube Computers & Internet
I phone and i tunes
it sounds like either a faulty usb socket or a driver issue with usb on your system... do you use microsoft update to keep your system up to date and the drivers current? if not you should do so. If you have more than 1 usb socket on your computer try one of those... remember itunes/iphone/ipods use usb version 2 and may not work properly if you have the older usb 1 standard on your computer
Sep 17, 2008 | Apple iPhone 3G
Cannot install win xp
Hi Phine_24,
I think you've problem with Harddisk.Try to find spare one and install again it should work. Very strange is that if you remove your hardisk out and test externally it should sometime work fine but sometime fail.I think it's a starting sector or some check up that windows or hardware need and it couldn't access it.
May 04, 2008 | Computers & Internet
Computers & Internet Logo
340 people viewed this question
David Payne
David Payne
