Question about Miele WT945 Front Load Washer / Dryer
How do i remove the lid of a miele wt2670 wasing machine
Two small screws at the back and one on either side (behind little covers)
There are two hinges at the back, so lift off from the front up.
Posted on Jan 24, 2011
Removal of fasia on mieie w970 wasing machine to fit new on off switch.disp removed and 3 screws removed .right hand side is fixed dont want to force it.
Hi dear. Open the door. There should be 1 or 3 10mm bolts around door gasket remove them. Where soap dispenser Top LHS 3 T10 screws,remove them. Open Bottom LHS pin trap.Remove the drain hose from the cover and right underneath it, there is a clip. You need to push it down to open front panel from left to right. Then you can access it. Thanks.
Mar 29, 2016 | Miele Washing Machines
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Apr 06, 2015 | Miele Washing Machines
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
My wasing machine model no WM 3009 i have the problem with spin and drain problem message shows E03 kindly advise
check the switch that is operated when the lid is closed, if this is broken or out of adjustment it will cause your problem
Sep 09, 2011 | Washing Machines
Wasing machine not work
check the breaker
make sure it is plugged in
make sure that the water is turned on.
Close the lid/door
Jan 08, 2011 | Washing Machines
Miele WT2670 message on screen "waterproof system activated". How do I reset?
I've just had this fault on this model, Its caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie.
Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work.
You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics - I'd have had to wait 10 days!
Jul 17, 2009 | Miele Washing Machines
Can't find integrated tumble dryer & washing machine to fit 555mm
most intergrated machines if not all are 60cm wide you could be in trouble
Jun 27, 2009 | Washing Machines
Wps code
Simply disconnect it. Water completes the circuit - so you want to make sure it is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Washing Machines
Miele WT945 Front Load Washer / Dryer Logo
755 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
