Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
I have an emachine T5026 with an Intel motherboasrd. i'm trying to determine if it will support 2-2gb sticks of DDR pc3200? it currently has 2-256 sticks of DDR pc3200. it has 4 memory slots with a max of 4gb, i'm just not sure if it would handle all 4gb in 2 sticks?
  • 4,737 Answers
The answer is no, one slot doesn't support more than 1GB ram. You cannot install more than 1GB of Ram per slot. If you are upgrading your ram to 4GB, you have to buy four 1GB rams. If you haven't purchased, go for 1GB not 2GB.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 28, 2010
I want to extend the RAM memory on my NEC computer. The motherboard is a GA-8SIMLNF Rev.1.1. It has two memory slots and presently one slot is occupied with a PC2100U-20330-A1 256 DDR 133 CL2 memory. I...
Check your manual (Gigabyte will have the manual on their website), to make sure your motherboard can handle 1Gb of Ram, or more. Generally in my experience, medium aged motherboards handle 1GB per slot, max (mine uses PC3200, not PC2100, and will take up to 4GB in its 4 slots).
You'll want PC2100 ram (easily searched for on http://www.newegg.com), either in 2x512MB sticks, or a single 1GB stick for your open slots (bringing you up to 1.25GB).
Mar 01, 2011 | Intel Motherboard
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
My desktop has intel 845gvsr board, n have a 256 mb ram installed on it. i want to upgrade it to 1gb what kind of ram should i go for
Each memory slot can hold DDR PC2700 or DDR PC3200 Non-ECC, Non-buffered RAM with a maximum of 1GB per slot.
You can refer to this site for more info on your RAM and motherboard.
http://www.crucial.com/store/listparts.aspx?model=D845GVSR
Thanks for using Fixya.
Feb 23, 2010 | Intel D845GVSR Motherboard
I got intel 845 gl motherboard having ddr 256mb pc3200 ram. there are two slots availble. i want to upgrade
If you want to upgrade your ram, buy the same memory frequency like your current ddr 256 mb pc3200 memory. You can upgrade your memory up to 4GB and be sure they have all the same frequency to avoid system complications.
Dec 19, 2009 | Intel Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
What speed,or memory that runs best in a syntax svm266a m.b.
The pc3200 would be best.
Do not mix different speeds together.
I'd go with the max of 2gig.
Mark
Mar 28, 2009 | Syntax SVM266A (SYSVM266A) Motherboard
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
