Question about Dell Dimension 2400 PC Desktop
Help - no sound from my reformatted dell 2400 computer
  • 1 more comment
  • jackhendri Aug 29, 2010
    Hi - when I try to download the file, the Dell Download Manager tells me "there are no files to download. Please go to Drivers and Downloads to select file(s)" Actually, I've been thru all this once and thought I had it set, the download required me to download "filetask" to read the application I downloaded. I restarted the comp. but still no sound. when I go to control panel, sounds, speech and audio, and Adjust the vol, it says no audio device. Anyway, thought I would try again.
    not sure what my last commun. was, but I have tried many fixes, to no avail. Last, I extracted the ADI 198x audio drivers from install cd - received an "error installing iKernel.exe" message. So I defragged my hard drive and tried again, same message. Just as background, under the volume control, the message is " there are no active mixer devices available ". Not sure if I already told you this, sorry if so.
    Thanks,
    jack
  • jackhendri Aug 30, 2010
    I solved the problem last night by going thru the troubleshooter (for the tenth time!) and setting the soundmax 2 as the default driver for the sound device. That worked.
    thanks for your help,
    jack
    President:
  • 4,070 Answers
Hi! The sound device driver may have been deleted. Please try to install the sound card driver to activate the sounds. Hope this helps and thank you for using FixYa!
Posted on Aug 30, 2010
  • 4,102 Answers
Hi the only way to get the sound back is to have a look and find out what model number the main board is inside your computer it will be printed on it somewhere so get a torch and see if you can find the model number, then go to google and type in the following
free drivers for ( here give your model number then hit search)
that will then lists load of sites that will let you download the drivers for *********** board you should find you need more drivers than just the sound like video drivers. you see what you need when you search ok
let me know if you need further assistance ok
Posted on Aug 29, 2010
  • Dell Master
  • 32,281 Answers
When you reformat the hard drive and then install Windows, the computer needs the device drivers (audio, video, LAN, modem etc.) installed again.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
  • Chris Hingee
    Chris Hingee Aug 30, 2010
    Did you try using the Service Tag?
    This will assist you to select the correct model laptop drivers.
Dell freezes up after reformat.
i recommend loading in safe mode and uninstalling your graphics drivers and installing the drivers from support.dell.com the reason i say this is because the graphics drivers windows wants to use via windows update occasionally will call erratic system behavior. you can also load in safe mode and go to start>accessories>administrative tools> event viewer. or simply press the windows key and the r key at the same time and type eventvwr and press enter. once there go through the logs and look for red X's or exclamations (can't remember which off hand) and see if you can find out what happens when it crashes.
Jul 30, 2012 | Dell Dimension 2400 PC Desktop
How do I clean my hard drive before i get rid of my computer?
With a floppy or cd do a reformat. Do it this way
Format c:/ s
What you are telling the computer is system format so when the next person loads windows, windows will see the harddrive
Jul 25, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimensions 2400 computer system. I
You will find the drivers you need at the link below:
http://supportapj.dell.com/support/downloads/driverslist.aspx?c=in&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Apr 16, 2009 | Q-Lity BX (P3BX) Motherboard
No sound from sub woofer---just humming sound when turned up
Make Sure you have connected properly. If you purchase the speakers from DELL, Click here download the manuals.
Thanks, PREM
Mar 28, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 audio issue, need help!
Jeffiorio, Well it appears that you have done everything correct. However for this particular model, there are at least 3 different audio drivers available. I have ran into this problem myself within my shop a time or two before.Try one of these it will be correct for your PC.
http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Jan 22, 2009 | Dell Dimension 2400 PC Desktop
Reset
You can put the restore disk in if you have them. This will reformat the hard drive and reload your operating system.
Jun 27, 2008 | Dell Dimension 2400 PC Desktop
No audio
Hi
Quite likely, drivers for the audio controller is missing/not installed.
You did not give any info on the Operating System you installed and the sound card in question; Onboard or PCI Sound Card. I am assuming you have Windows XP or 2000 and using the builtin/onboard sound controller.
If this is correct, you will need to download and install ADI Onboard Sound Driver (Windows 2000/XP) - http://ftp.us.dell.com/audio/R94481.EXE
Let me know how you get on
Mike
May 25, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
47 people viewed this question
Alun Cox
