Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
I need to replace the Amphenol Plug and I cant see how the wire connections are made and no instructions come with the replacement part
    President:
  • Smart Master
  • 1,378 Answers
White goes to 2 and black to 3. If you have a read wire it goes in the ground hole. The final hole marked 1 should be empty no matter what.
John
Posted on Aug 28, 2010
  • 1 more comment
  • kgoodwin539 Apr 22, 2011
    I have a similar problem, so this information is very useful.
    Now, I have a rather embarrassing question. How do I get the wires in to the "holes"? It doesn't seem possible to just push it in, nor is there any obvious screw mechanism.
  • John Prohaska
    John Prohaska Apr 22, 2011
    The small set screws enter from the side of the hole and there is a small tensioning strip of metal wedged into the hole. Relieve the set screw enough to open the hole some then use the allen wrench (I believe the correct sive for the set screw is 1.5mm) and insert it into the hole a wiggle it the move the wedge to be more open. Insert the wires with the wedge still in the hole then tighten the set screws back down.
  • Tony Goetz
    Tony Goetz Aug 15, 2013
    Thank you for the correct hole #'s John. Works like a champ again!
I need instructions on how to change spark plugs and wireset on a 1995 subaru impreza l 1.8
Since you are unfamiliar with this process, do these steps one spark plug at a time. Locate the spark plugs; remove the wire's connecting cap from the plug; remove the spark plug from its threaded hole (use a dedicated spark plug wrench or socket of the proper size - may be a 16mm, 5/8", or possibly but unlikely 13/16"); check the electrode gap on the new plug and install it in the threaded hole; follow the plug wire back to its individual coil (opposite end from the spark plug; remove the old plug wire and replace it with the new one of the same length ensuring the same wire routing; replace the plug wire cap on the new plug; move on to the next and repeat.
Oct 05, 2013 | Subaru Impreza Cars & Trucks
Plug going from machine to power pack is broken. It is an amphenol? plug I believe. The plub came apart and wires inside are broken. I have contacted 2 of the companies on the Maytronics site that say...
<P>Put the white into hole 2 and the black into hole three. If you need a new amphenol plug, please contact me thru our site at <A href="http://www.arrowpools.net">www.arrowpools.net</A>. We are also on that list under Arrow Motor &amp; Pump.</P><P>&nbsp;</P><P>John</P>
Aug 23, 2010 | Dolphin Maytronics Diagnostic Robot...
How do you replace headlight? skipper skipper39@gmail.com
I just replaced mine about 30 min. ago. There are two Phillip head screws at about 4 o'clock and 8 o'clock on the main body of the head light. Do not mess with the two screws on the ring on front of the headlight. Now the ring and the glass part will separate from body of the light. Unplug the amphenol plug and lay the light face down on a towel on your work bench. Remove the black plastic cover and then release the locking spring. The halogen bulb will lift out. I bought a replacement bulb at O Riley's for less than ten dollars. Now reverse the procedure.
Jun 17, 2010 | 2003 Yamaha V Star 1100 Classic
I need to replace plug on my skull candy smokin buds
the copper wires both go to the common/ground of the plug. those wires both connect to the contact that is closest to the cable. the other two connect to the other 2 contacts just pick either or.
Oct 08, 2009 | Skull Candy Smokin' Buds Headphones
I cant get it to start i replaced spark plug
Does the new plug spark outside of the engine? Put the base on an unpainted part of the engine with the plug wire on and kick it through a few times. Does this engine require a battery to run or is it a self-contained ignition system? Remove the fuel tank and check for loose wires or other parts. If it requires a battery, check the connections at the battery for corrosion or looseness. Is the battery charged?
Sep 02, 2009 | Honda CRF 230 F Motorcycles
There are two amphenol connectors on the samsung dcs50si. Which one is for the co lines and which is for the keysets?
Try tracing co lines cross connect cable and see where it is terminated. This is your co. Other amphenol should be keyset
Jul 28, 2009 | Lands Phones
Replacing spark plug wires on 1995 Buick Riviera
You need to drain some coolant. Loosen and disconnect water lines by the firewall- the ones in the way of your wire change. u need to get a diagram of the firing order of the engine so that those wires are correctly connected to the coil packs.
Mar 21, 2009 | 1995 Buick Riviera
PL-259 to RG-8X
Here is the instrucktino in PDF format:
http://www.ppraa.org/downloads/tech_talk/Pl259%20soldering%20Short%208x.pdf
Here is a website with instructions and illustrations:
http://www.antennex.com/hws/ws0801/reducer.html
These will help you out tremendously.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 19, 2008 | Radio Communications
31-315-RFX
solder a 50 ohms 1/2W resistor to data lead to the body ground of amphenol connector
Feb 21, 2008 | Amphenol Coaxial Network terminator...
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
1,255 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
