Question about Dell Inspiron 1545 Notebook
Computer will not boot up, "internal hard disk not found"
  • 154 Answers
Hi, first thing to do is not panic!. Have you tried switching the machine off for five minutes and then turning it back on? If you still have a problem, power the machine off, open up the underneath panel which holds the hard drive (see your manual for which panel or look for one appx 8cm by 4cm. there will probably be one screw which you have to remove. to remove the hard drive once the screw is removed, pull the plastic band along the axis of the hard drive until it unplugs from the connector. Then reverse the proceedure! This will reconnect the hard drive and clean the connector terminals symultaneously. When the laptop is back together, try powering up again. If this doesn't work, contact me again. Kind regards
Posted on Aug 28, 2010
    Novelist:
  • 101 Answers
The issue described in your post indicates the hard drive has malfunctioned. Some (but unfortunately no all) Dell desktop/laptops come pre-installed with diagnostics software to help troubleshoot hardware trouble. To check for this feature, follow the steps below:
1. Power on the computer/laptop. 2. At the Dell logo, press and hold down the "F12" key. 3. Following the boot screen, there should be a list of options if the command was input properly. If the list is available, select "Hard Drive Diagnostics" or "Diagnostics" from the list. If the list is not present, repeat steps 1-2. 4a. If "Hard Drive Diagnostics" is present, the system will run an automatic self-test and after a few minutes it will return a message or error code. An "Error Code #7", "Not Pass" or "Hard Drive Not Found" indicate that the hard drive has malfunctioned and will need replacement. 4b. If "Diagnostics" is present, the system will initialize the application and present you with a list of components to check. Use the mouse pointer to highlight the "Hard Drive" category and double-click it to run the test(s). This may take 15 minutes to over an hour to complete. Upon completion, a list of error(s) found will be displayed on-screen. If either 4a or 4b display error messages/codes and your system is still covered under warranty, click the link below to speak to a Dell representative that can assist you in getting the hard drive exchanged and your system up and running again.
http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?c=us&cs=19&l=en&s=dhs&~ck=anavml
If your desktop/laptop is no longer under warranty, than a hard drive replacement will need to be purchased and installed in order to be able to reinstall your OS and get your computer working correctly. A replacement hard drive can cost anywhere from $35-200, depending on make/model/size.
The removal of the old hard drive and installation of the new, replacement part is not terribly difficult, but if done be inexperienced users, it could render other parts of the laptop faulty due to user error.
5 Suggested Answers
  • 4 Answers
SOURCE: no internal hard disk found during booting when i am going to format
It is possible that the HD has failed completely. However, this is a relatively new laptop, so I would suspect that is not the case. Sometimes the HD will lose contact for one reason or another. This can usually be cured by removing the HD and reinstalling it, which will remove any crud from the contacts.
http://www.fixya.com/support/t1639067-reseat_hard_drive
If the machine is still under warranty, call Dell support. They will walk you through diagnostics to determine the actual problem.
If you're not sure of the warranty status, go here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
HTH
Posted on May 24, 2009
rickyostrom
  • 274 Answers
SOURCE: thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Posted on Nov 19, 2008
CptOblivious
  • 5 Answers
SOURCE: reseat the hard drive
shut down the laptop.
then, disconnect the laptop power, and battery.
remove the harddrive, then connect the harddrive firmly back into place.
reconnect power/battery and boot.
Posted on Mar 25, 2009
leecom72
  • 4806 Answers
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Flashing question mark on macbook
The problem is the MacBook is unable to find the "designated" boot device. The problem can caused by several things. The most likely is also the worst possible cause. The most likely problem is that the hard disk is not working correctly. To diagnose the problem follow the following steps:
  • If you have your original disks, boot the install disk
  1. Restart the computer
  2. Insert boot disk in the optical drive as soon as you turn on the computer
  3. Hold down the 'c' key on the keyboard to signal the MacBook to use the optical disk to boot the computer.
  4. Once the computer is booted, use the Disk Utility from the Utilities menu to examine and if necessary repair the hard disk.
  1. Start by ensuring that your internal hard disk is listed.
      • If your disk is not listed, then your hard disk is definitely having a problem. If you are lucky, it maybe just that one of the cables has become disconnected. I believe on your MacBook, the hard drive is accessible by removing the battery and the hard disk is located next to the battery. You would need to post your model number to get exact instructions.
  2. If so, then run the Verify Permissions and Verify Disk. Run repair if there are any errors detected.
  1. Once you have checked and repaired the hard disk, exit Disk Utility and run Startup Disk from the Utility menu.
  2. Select your Hard Disk and click Restart
If you are lucky, the computer will run again. If not, check your install discs. The original install discs usually have a hardware diagnostic which can be run by holding down the 'd' key while booting. You can try running the diagnostics to see if you can diagnose the cause of the booting problem. You can also use the diagnostics if your hard disk is not shown in the Disk Utility to run diagnostics on the hard disk.
Post the results of your testing so I can help further or know that you have found a solution even if it is to get a new hard drive and restore your system.
Thanks, Jim
Aug 14, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When i open my acer 4047 just displyd for setup key f2/f12 to pres,then i press f12 to reinstall new windows but there is i dont fine any hard drive?
Seeing as this is an approximately 8-year-old laptop, if you are getting a message that no hard drive is found, you have one of two issues.
Either your BIOS has reset itself and is not looking at your internal hard disk as the boot source and the message is not hard drive not found but boot disk not found .... OR ..... your hard drive has suffered a failure and needs replacement.
Jan 14, 2012 | Sony VAIO PCG-K25 Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
As soon as I turn on my laptop a message says that the internal hard disk drive was not found and that I should reseat the drive.
Yes that is the first thing your should try.
When the computer cannot detect the hard disk or a boot disk then you get this error message. Please click on this link to determine the fault and solution to this problem :-
http://www.fixya.com/support/r6244569-no_bootable_device
Oct 18, 2010 | Dell Inspiron 1525 Notebook
When i boot my dell laptop, it fisplays "internal hard disk not found"
Go to BIOS and disable option - internal hard disk, if you haven it.
Instructions how do this you find at "User Guide"
Sep 21, 2010 | Dell Inspiron 6400 Notebook
My toshiba lap top starts up as normal then the msg media test faiure and no bootable device whats wrong
The laptop isn't seeing the hard drive. It has either bounced loose (doubtful) or the hard drive is defective. You can open panels on laptop and find the hard drive, remove and then replace it and see if it reads. Failing this check to see if it's still on warranty or buy another one similar to yours.
Nov 27, 2009 | Computers & Internet
No operating system found
If the error message says "No operating system found" it is most likely a faulty disk controller or a faulty hard disk.
Reseat the hard disk, if this doesn't work you need to test the hard disk another way. Remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer sees this as an external hard drive and you can open the folders and files then the hard disk is OK and the fault is the disk controller on the the 4115c laptop.
If the hard disk is not detected then the hard disk is faulty. You need to install a new hard disk, install Windows and the laptop's device drivers and programs to get a working laptop again.
Sep 11, 2009 | Computers & Internet
Reseat the hard drive
Mar 25, 2009 | Dell Computers & Internet
Dell Inspiron 1545 Notebook Logo
350 people viewed this question
Alun Cox
