Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
The machine moves but the fan does not turn, the motor is humming
  • 640 Answers
Occasionally hair or linen may get caught in the impeller. If that happens, take the top grill off by removing the 2 screws from the top. Make sure that the transformer is unplugged. Remove the debris. Replace the top grill and tighten the 2 screws. This is most likely what is causing the trouble with this automatic pool cleaner.
Posted on Mar 08, 2011
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
Waterway pool pump is humming but fan is not turning
Shorted motor windings, can you move the turbine when turned on or does it feel like it is being held in place. WARNING!!! do not try with your hand, use a tool. Possible capacitor, but I would suspect motor to turn slowly.
Apr 02, 2013 | Waterway Pool & Spa
My 230 bernina does'nt move when I press the foot switch, just humming.
Sounds like the motor is either frozen or the machine is frozen. Humming means the motor is trying to turn. Is there an external hand wheel which will allow turning the machine by hand? If the machine has been in storage for a long time, the lubrication can become 'glue-like' causing difficult turning. This may require a trip to a service shop--hope this helps!
Dec 27, 2010 | Vacuums
Why does my electric fireplace makes a humming noise when on?
sounds like you may have a ceased fan get someone to look for you, but an electrical hum that is louder than normal usually means that the fan or a moving part is trying to turn ot move but can't so make's like a hum noise so seek a service agent
Dec 15, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
GE Dishwasher motor hums but doesn't engage.
These motors will stick sometimes during periods of not being used. With the power turned off to the the dishwasher, remove the front lower grille. There are usuallly 2 screws on each side of the panel. Looking under the D/W your will see the motor and pump assembly. If you feel around you should be able to feel the motor's cooling fan. Simply rock the fan back and forth and the motor/pump should become unstuck.
Jun 21, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Kenmore 80 series wash machine humming
you have a clogged pump
the pump is hooked directly to the motor if thats cogged the motor cannot move producing a humming sound
Oct 07, 2009 | Washing Machines
The ceiling fan hums but the blades dont move when turned on
Your fan motor went bad. Cheaper to replace fan than repair motor.
Aug 18, 2009 | Dryers
Motor can be heard going but the blade wont spin!!
There is usually a pin in the shaft of the motor, that corrosponds with a slot in the fan blades, it sounds to me like either (a) the pin somehow came out, or (b) the slot in the blades is rounded. Hope this helps
Jul 15, 2009 | Patton 20" CVT Performance Air Circulator,...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Fan not turning, but motor is humming
might want to check the fan motor start capacitor
Jun 09, 2008 | Hampton Bay HBLG5004 Air Conditioner
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
180 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
