Question about Garmin 010-00358-00 GPS Receiver
Just stopped working...shows my car off of the road when its not and doesnt give correct directions
  • 11,800 Answers
It appears that the unit is frozen.
First of all remove the SD card and shut the unit down, wait 5 minutes and restart it. If it's the same then reset the unit (how you can do that is explained in the unit's manual). If it's the same then remove the battery, wait 1 hour and start it again. If even after that it's the same then your only remaining option is to update the firmware: go here and follow the instructions
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
If you can't update it or it behaves the same after the update then the defect is hardware and fixing it would cost you more than a new unit.
Just junk it and buy a new one.
Posted on Aug 28, 2010
Garmin receives sat signal ok will give directions - basically everything operates normally with the exception that the actual map on the screen does not show anything.
Go to your settings and check what options have been selected. You may have to revert to the default settings and then tweak your preferences.
Sep 20, 2016 | Garmin nuvi GPS
2004 seems to loose fuel pressure periodically while driving down the road
i have a supercharger in mine and if i run less than superios gas it will do this as well, good bet use shell premium gas and that should stop if it doesnt try replacing your fuel filter its just under the body of the car at the front edge of the driver side door :)
Dec 14, 2011 | 2004 Pontiac Grand Prix
Get directions on life source 767 monitor
Would suggest you try looking in the manual section of www.retrevo.com
Feb 25, 2011 | Life Science Life Source Blood Pressure...
My Garmin cannot find the lake house. Directions
You may need to update your maps. If they are up to date (2010) then its just bad data from Navteq. You can add the waypoint in your nuvi and custom name it which would provide better results.
Aug 15, 2009 | Garmin Nuvi 350 Car GPS Receiver
Volkswagen lt 2.8 cut down on the road, when i restart works
If it sputters to a stop, then I would suspect fuel delivery problems, If it stops abruptly, then likely loss of ignition power (fuse?) or loss of the crank or cam sensor signals. You need to have a code reader attached while driving, that records intermittent faults, to track this one down. It could also be the computer itself!
Aug 08, 2009 | 2005 Volkswagen Microbus
Sat nav stopped working
Mercedes commans sat nav version 4.1 for E220, is saying off road, and when at home is showing on map that I am somewhere in the National Park Peak District. I have been told to remove fuse for sat nav should be no 28 but in boot of car near sat nav cassette fuses in box only go upto 20. Am I looking in the right place?
Jun 30, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Cavalier dies
you need to find the fuel pressure release around the fuel rail press the little tab when the car dies. If there is no fuel coming out from that point, your fuel pump is going.
Aug 03, 2008 | 2000 Chevrolet Cavalier
Device can not "locate" correctly
Turn it on and let sit until it locates itself mine does the same thing only when moving down the road but when I stop it seems to work itself out and then works fine till I turn it on going down the road again
Feb 23, 2007 | Magellan RoadMate 300 GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
18 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
