Question about Canon FAX-L200 Plain Paper Laser
Display show check printer, error code ##322 - Canon FAX-L200 Plain Paper Laser
    Guru:
  • Canon Master
  • 452 Answers
The error code ##322 appears when the fixing unit is not working. the heater does not reach the specific temperature. check the resistance of the heater, or a pooor contact . but the best solution is replace by a new fixing unit
Posted on Oct 26, 2010
How do I over come a problem with my Ricoh Aficio 1515MF, whenever I try to power on the device the device display screen says Functional error SC:322. power off then on if problem persists call servi
Service manual & troubleshooting says this error related to laser unit but this is final solution. To my experience this error mostly because of Micro Door Switchs. Try it by changing Micro Door Switch. I am sure it will help you
Dec 24, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
FAULT CODE 094-322. WHAT CAUSES IT AND HOW DO I GET RID IF IT?
ERROR CODE 094-322 RAP Second BTR Retract Failure
The error relates to the Second bias transfer roller not retracting. It could be a fault with the roller but i would open the transfer draw and check the connections and seating of everything and try it again. More often than not this clears the error.
Jun 24, 2011 | Xerox DocuColor 12 Color Copier
Ricoh Aficio AP 2600 laser printer there is a code SC-322
On most Ricoh models, SC-322 is a problem with the laser unit. If you have a service contract, have your technician take a look at the printer. Otherwise, you can either have a local Ricoh tech give you a repair estimate or buy a new printer.
On rare occasions you can turn the printer off and turn it back on and the code will be cleared, but most of the time this is a serious error that requires a service technician.
Apr 28, 2010 | Ricoh Aficio AP2600 Laser Printer
Error coad 322 is showing. what i do now?
ERROR 322 is Laser synchronization error
Detected LD error signal for
continuous 1.5 seconds while
polygon mirror motor was
running at constant speed.
Possible Cause • Synchronization detection mirror
defective
• LD unit defective
• FCU defective
• LD harness damaged
• THM not in place
Jan 08, 2010 | Ricoh Aficio 1013F Copier
CHECK PRINTER ##330 flashing message
From the message board archives:
Error codes:
## 322 Fuser not heating (Usually Bad Fuser Module)
## 323 Laser Beam detect error
## 324 Laser scanner motor rotation incorrect
## 325 Fan motor inop
## 330 Power Supply (Replace/Repair)
You must turn on error management to have the machine display error codes, otherwise it will just say "CHECK PRINTER".
To turn error management on, enter the following: Press Data registration, #, Set, 00000011, set, stop. Now after the "check printer" message there should be one of the error codes above.
Supposedly, Nation-Wide Repair Service fixes the bad power supplies for $45.00. They can be reached at 800-798-1814. You can also buy one for $148.00 from www.loyal.net I hear. The proper replacement power supply part number for both the LC7000 and LC7500 is HH3-5278 so I am told.
Aug 04, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
##322 error on display
Fixing unit faulty and it can be replaced!
May 12, 2009 | Canon L220 Plain Paper Laser Fax
Canon Laser Class 7000 Fax won't print
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
Mar 03, 2009 | Canon LaserClass 7000 Plain Paper Fax
Error #322
Try cleaning the "rollers" in the track where the paper feeds through. Look for small pieces of paper that may be logged where you can't readily see them. Look carefully. Once you clear the paper path it should work.
Dec 05, 2007 | Office Equipment & Supplies
Canon FAX-L200 Plain Paper Laser Logo
563 people viewed this question
old marine
old marine
