Can I replace a blown fuse in my TX-8211 onkyo receiver, and where do i find such a fuse?
  • 21 Answers
SOURCE: Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Posted on Sep 03, 2007
SOURCE: Blown Fuse, needs fix'n
Regarding the last answe, how do you know if it is slow blow or fast blow?
Posted on Jan 21, 2008
  • 4234 Answers
SOURCE: i have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Posted on Nov 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: Onkyo TX 8211 protection mode is activated and i
Eliminate the short or overheating problem it thinks exists. Disconnect all speakers first to see if one of them is the culprit. If it's internal, take it to a shop.
Posted on Jan 21, 2010
Grubhead
  • 5190 Answers
SOURCE: Can I play my ipod through my Onkyo TX-SR600 receiver?
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Posted on Mar 30, 2010
Testimonial: "Thanks so much. Great solution."
What is the signal to noise ratio of the onkyo tx-8211 at its phono input
Why not enter the info into a search engine? Or try their site . . .
SEARCH ENGINES ARE YOU FRIEND!!!
Sep 11, 2015 | Onkyo Audio Players & Recorders
Onkyo tx 8211 receiver shut off problems
Check all of your speaker wires and speaker turminals. I bet there is a short.
Apr 26, 2012 | Onkyo TX-8211 Receiver
TX-8211 FM Stereo/AM Receiver All has been fine
make sure that somehow the wires didn't get loose from the speakers in the back. Protect means that it's overloaded. Did you change the plus wires with minus wires maybe. Check to make sure all the wires are good.
Mar 19, 2011 | Onkyo TX-8211 Receiver
I have a TX-8211 but I am out of town looking at Internet Radio tuners. Can you tell me what type of inputs are on the Onkyo? I know it has the black/red spring loaded wire inputs but are there other...
Your tuner will be the limiting factor regarding sound. The Onkyo accepts any stereo analog input via RCA connectors, period.
Those "black/red spring loaded wire inputs" are speaker outputs and if you hook one of those to an innocent audio device's Line In connections you might kiss it all goodbye.
Read the manual...
http://www.retrevo.com/support/Onkyo-TX-8211-Receivers-manual/id/365ci165/t/2/
Feb 01, 2011 | Onkyo TX-8211 Receiver
If I increase the volume control, the sound goes out and the unit says protect
This is a piece of **** receiver. Ive had the same problem since it was brand new.
Dec 15, 2010 | Onkyo TX-8211 Receiver
Onkyo TX 8211 protection mode is activated and i want to know how to deactivate it????
Jan 19, 2010 | Onkyo TX-8211 Receiver
Onkyo tx-8211 protect
It's unlikely you can. Most hifi shops can though.
If you're still reading, open it up, and look for a switch of some kind. It may not even exist, but I'd say it's the best thing to look for when doing something considered mediocre at hifi shops (if it was difficult and interesting, they wouldn't find it so boring). Maybe it's a button. It will probably be labelled protection or reset or something similar.
So, look for a switch, or something similar. I have no idea where it would be because I've never dismantled such a thing. The other option (if you haven't done so already) is unplug it from the power and leave it for a while (overnight may be the best bet). This may fix it for you, and it's easier than undoing all those screws.
Jan 13, 2010 | Onkyo TX-8211 Receiver
Onkyo TX8211
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Dan
Aug 12, 2009 | Onkyo TX-8211 Receiver
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
59 people viewed this question
 Grubhead
Grubhead
