Question about Samsung Washing Machines
My samsung vrt front loader will not drain or spin and showing nd code
  • Anonymous Mar 21, 2014
    WF511ABR spin knocking
  • Anonymous Mar 23, 2014
    won't spin nor drain
  • Samsung Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 28, 2010
My samsung front end loader goes out of balance during the spin cycle. Is not making any noise. Flashes an "nd" code.
as far as I am aware the ND code means not draining would check your drain hose pipe or the filter could be blocked causing it not to drain properly while spinning
Oct 15, 2017 | Samsung Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
Nd code and stops at spin cycle
And code fans no drain you have to unclog your pump. Depending on your model access is in lower front or in the rear. Pull out your washer unfortunately you will have to unbail it. If pump clean out access is in lower front turn the filter head counter clock wise and clear any debris.rear access remove to hose it should be held in place with two 7/16 the nuts remove and clear debris if that doesn't clear code it may have clogged again with excess debis clear again good luck! Howevver may need to replace the pump
Jul 24, 2015 | Samsung 3.9 cu. ft. Vrt, Steam and...
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Washer won't drain & spin with full load
Sounds like your drain is plugged. Your drain hose has debris in it and you need to get at the drain pump hoses and clean them out
Jan 13, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Samsung front loader not spinning at high speed
Yes ! this is related to fabric and hair accumulation and so it will be best to check the drain filter when you experience this issue.
Dec 30, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
What does the code nd stand for?
this is a no drain error or slow drain issue you need to check for anything that would or is restricting the water from draining out of the tub.
if the water will not srin then you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
then check all your hose to and from the drain pump
Apr 13, 2010 | Amana LWA40A
Washing Machines Logo
1,752 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
