Question about Nikon D50 Digital Camera with 18-55mm Lens
D 50 Lens not openning fully. in mirror lock up my lens does not go all the way open should this happen? when taking photo's I have and un-exposed area at the bottom of the photo, I don't think the lens is fulling opening
    Novelist:
    Champion:
  • 214 Answers
Hi - not really sure of the problem but I think it is the shutter not opening fully during the exposure. If this is the case a camera repairman should be able to fix it.
Is the camera still under warranty? If not, get a quote for the repair (as this may mean replacing the whole shutter mechanism - not cheap) and see if it is more economical to repair or replace the camera.
Better hope that it is still under warranty.
Sorry I don't have a quick and easy solution for you.
Good luck.
Posted on May 08, 2008
Why would my Auto focus mirror not folding up completely.
The mirror is designed to fully swing from top to bottom with out any interference unless something was jammed inside. If you are shooting with the lens off and watching the mirror only partially open something is jammed and needs repair. To test this put the camera in Manual mode ( M on the mode selector dial) Set the shutter speed to 1/4 of a second and press the shutter button. Having a slow shutter will allow you to see if it is fully opening and closing.
If you are making this assumption based on seeing images that have only a portion of the frame exposed, then the most likely scenario is you are taking pictures with the flash on at a shutter speed greater than 1/250 of a second. This causes the flash to fire before the shutter is fully open and therefore only part of the frame is exposed. Google "Shutter Sync Speed".
Good Luck
Feb 27, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
I have a Canon AE 1 35 mm camera. I use a zoom lens for sports'. When you look through the lens you see a lot of particals, and the pictures come are bad. It use to take wonderful photos. I removed the...
As the mirror moves up out of the way when a photo is taken this will have no effect on your pictures. The amount of dirt that you describe does seem to indicate that the camera is very dirty. You should clean it carefully, use no oil, anywhere, get all the dust and particles you can out of the camera. If there is dirt in the film transport area this will probably scratch the film as you wind on each time. The only dirt that will come out on the photos is any that is on the film when the photo is taken; these will be different each photo, or any on the back of the lens; these will be the same on each photo, but different for a different lens. Cleaning "the black part" from the lens side... this is actually the shutter itself, and is made from very thin metal. If you have bent or damaged this when cleaning it, you will have probably scrapped the camera. This can be changed, but only really by a repair shop. Again, dirt on this, either side, will not appear on photos, but might fall onto the film during exposure, leaving under exposed dust marks. Shutter blades can get tangled up, and not work nicely, not close properly. Try pressing the shutter with the back open and the lens off, looking through and see if there are any light leaks when the shutter is supposed to be closed.
Dec 31, 2010 | Canon Photography
I have D90 dslr camera last few months was working very fine but last days its shutter not opening propely after click only half image show
Your mirror is not fully opening, make sure you have no dust or object jamming the mirror. Do a cleaning with the mirror locked up in the raised position.
Mar 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
Lens cap off but pictures all black. Tested another SD card same thing happens. Black on review on camera and black when put SD card in computer. Camera a few years old and never had a problem before....
Is this a Canon ? If it is, you need to call Canon. You might have a CCD sensor failure.
Take a look at http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
If it is not a canon (You do not mention the brand) you are still best to contact the vendor. CCD failures can happen accross the board.
If the lens is a removable SLR type, take of the lens and take a photo. Does the mirror flip up at all and expose the CCD ?
Thanks
Feb 09, 2010 | Pentax *ist DL Digital Camera
Tiny black dots and a hairline mark now appear on all my photos using a Nikon D40
You might have to have your sensor cleaned. When the camera body is exposed to excessive amount of dust they can get in the mirror housing. When the shutter opens and the mirror flips out the way when a photo is taken, it aggitates the dust then it falls on the sensor. It will need to professionally cleaned by a repair technician.
To test it is dust, take a few photos of a white wall at aperture f22 with the flash on and if they are all consistant that is problem. They will look like soft black blobs.
Oct 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Sony Cyber Shot lens extends and retracts, can't take photo
My solution for the M340
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Sep 13, 2009 | Kodak EASYSHARE M340 Digital Camera
Pentax MZ50/ZX50 - no photo when shutter is pressed
first make sure the mirror is fully down. if down
take your MZ50 to a camera store and try a different lens. if it does the same thing then your camera needs repaired. flex circuit,
if the different lens works then the lens needs repaired.
Jul 20, 2009 | Pentax ZX-50 35mm SLR Camera
Camera comes on but not able to take photos
dang see what happens if you take the battery out while the lens is oppening or when it opens fully
Apr 15, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
F--
Try removing and re-installing the lens. If that doesn't do it, give the lens a little extra twist in either direction. The contacts may not be lining up just right. If still no better, take the lens off the body and inspect the contacts at the top of the lens opening in the body, and also the contact points on the upper portion of the lens mounting flange. Gently clean with some alcohol and a cotton swab.
Jan 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
Camera won't take a picture
It could be that the shutter has gone out or the mirror is not going up they are only rated to last for so many shots. That is what canon told me when my 10d did the same thing. I dont remember what the repair cost was.
May 28, 2007 | Canon Digital Rebel / EOS-300D Digital...
Nikon D50 Digital Camera with 18-55mm Lens Logo
51 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
