Question about Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater ()
I get the error code of SMS, can I still turn the heater on. I have a Rheem pool heater
5 Suggested Answers
  • 11 Answers
SOURCE: Pool heater sparks but does not light up
coud be several things, Do you have Gas and is gas toruned on. Is valve on. The Pilot could be dirty and need cleaned. $350+ sounds reallly pricy for a pilot assembly. Call your Gas Company and get an Estimate and a Qualifed Service tech. You may try turning Off the Power to the Heater Unit and turning it back on , and then trying to turn on heater again, So times after several atemps the valve will lock out and the power needs reset on Propane units.
Posted on Jun 29, 2010
macdirk
  • 116 Answers
SOURCE: I have a Rheem raypack pool and spa heater. I have
Error Code ROL is "HEAT ROLL-OUT SAFETY SWITCH OPEN". The heater is equipped with a cutoff device to prevent flame roll-out in the event the heat exchanger becomes blocked. This is either a "manual reset", or "Single-use" type fusible link/thermal fuse, that must be replaced or reset after any over temperature conditions have been fixed. Excessive restriction in the heat exchanger flue passage may cause the switch to disable the heater. I don't know your exact model so I'm just generalizing. If you reset or replace the switch, and it trips/burns out again, then you need to address what is causing it. make sure the heater is cleaned out well and no debris is blocking the flue. I fthis doesn't help you can always try calling Raypak Service department at (805) 278-5300.
Posted on Sep 20, 2010
john224
  • 1378 Answers
SOURCE: What is the manufacture year of the rheem
What is the serial number? The 337A series has only been around since the end of 2004 so it will be somewhere in the last 5 or so years.
Posted on Oct 27, 2010
Testimonial: "thanks. I'm selling it and the buyer wanted to know the manufacture year, and I couldn't find it anywhere on the rheem website. I appreciate your help"
  • 366 Answers
SOURCE: PROPANE RHEEM POOL HEATER IGNITES AND HEATS UP,
sounds like you have a bad thermal governor (regulates water temp inside the heat exchanger) or your pH has been to high and your exchanger is completely scaled up.
Posted on Aug 18, 2011
What does ILO mean?
Ignition lock out
This happens when a safety feature kicked in and the heater tried to start up again. Turn the power off at the breaker for 10 seconds and try again.
It should fire up or give an error code for possible issues
Aug 04, 2014 | Raypak Rheem RP2100 399K BTU Natural Gas...
Rheem pool heater code ifault
check gas pressure if ok then turn up by calibration
Jun 30, 2014 | Pool & Spa
What does CFH mean
this is not an error code. it means a call for heat. the pool water temp is colder than your tstat set point
May 25, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Heater shuts down and message says "Fan Lockout".
Shut off the breaker to the heater and turn it back on to reset heater and clear error code.
Oct 16, 2013 | Rheem 266K to 399K BTU Swimming Pool...
RHEEM POOL HEATER HL2 ERROR CODE
high limit bad replace and check gas pressure
Mar 12, 2012 | Rheem 266K to 399K BTU Swimming Pool...
C4 error code on RTG-53DVN
The C4 is a sequence number, there should be a series of numbers that flash after the C4, what is that number?
If you want to see the entire error code list for the Rheem tankless hot water heaters, it can be found at this link:
http://www.emshvac.com/Rheem_Tankless.htm
Aug 19, 2009 | Rheem Tankless Water Heater Manifold...
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater () Logo
46 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
