Question about Garmin Nuvi 660 GPS Receiver
I have a Garmin Nuvi 660. Whenever I turn it on, it says "Updating Bluetooth Firmware". the problem is, it never updates and the unit will not advance past this stage. i have to use the reset button to turn it off. I drove for 4 hours yesterday and it would not update or do anything except flash this message. help
  • Garmin Master
  • 2,130 Answers
I believe we already helped you with this one via email but I've written some instructions here:
http://www.sharc.net/discus/messages/6/388.html?1283524439
- Jim
Posted on Sep 03, 2010
It won't load the maps and goes to a screen saying "updating bluetooth firmware" then shuts off on its own
Before installing any maps, check for any updates are standing by. install the updates first , start it and check the operation is normal like before, and then go for the maps.
Jul 29, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 760 ...updating bluetooth firmware
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI
To reset your NUVI , please follow one of these procedures :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
After that you can try again with updating .
PLEASE DON'T FORGET TO RATE !
Apr 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
My garmin nuvi 660 lost satellite connection
RESET OR TURN THE DEVICE OFF AND ON AGIN IT MAY WORK. BE SURE U R IN AN OPEN AREA. CLEAR SKY R BEST. STANDING NEAR TO BIG BUILDING OR NERA POWER TOWERS MAY CAUSE TO LOOSE THE CONNECTION.
Aug 09, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Try performing a reset of the unit. Hold down the bottom right of the touchscreen and turn the unit on. It will ask you whether you want to reset allk data. Choose yes and try again. This should solve your problem. Hope this helps.
Feb 20, 2009 | Garmin Nuvi 660 GPS Receiver
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Feb 20, 2009 | Garmin nuvi 780 GPS
Nuvi 660 + omnia
Hi, version 3.1 is supposed to help with disconnects. Please see this link:
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109459
However, Garmin released 3.4 which will include the changes in 3.1 and also makes the bluetooth compatible with more phones.
You need to go to www.garmin.com and download their webupdater and run it with your Nuvi connected to the PC with a USB cable. It will check (via the Internet) if you need a firmware upgrade. The latest firmware version for a Nuvi 660 is v4.7. There is a second menu after the main firmware option that allows you to select additional software. Select yes and check the bluetooth 3.4 box and the Chipset "G" box if it's shown.. The Chipset "G" is the upgrade for the receiver in the flip-up antenna. Let it download. When finished, select to safely remove the Nuvi. You can now unplug the USB cable. Your Nuvi will reboot and load in the new changes. Whatever you do, don't turn your nuvi off! Let it go and update. You will see it say "Loader", then "Loading Software" and you'll see a task bar that says "Updating Bluetooth Software" and "Updating GPS Software" (if required). Once you get to the main menu and there are no more texts coming up on the screen. Press the power button and turn your unit off and then back on again. Check the GPS and Bluetooth firmware versions in your Nuvi. It should be 3.0 for the GPS and 3.4 for the Bluetooth. Check the firmware version if you selected v4.7. You will have to re-pair your phone with your Nuvi as the update erases any previous set-up. Let me know how it went for you. If you have trouble with this, let me know. I can do it for you. I have done it many times. Please rate my solution if you found it helpful.
- Jim
SHARCNET-USA
Jan 06, 2009 | Garmin Nuvi 660 GPS Receiver
Stop transfering voice from Sony Ericson P910i and Garmin Nuvi 660
Can you update the firmware on your unit
my k800i sony phone had a problem synchronising and would freeze, then one day the nuvi 660 updated the firmware by itself and has been fine since, only problem being the volume, a bit low when trying to contest with large diesel engine, onboard speaker keen to distort over 80% volume
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 BlueTooth
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin 660 gps Bluetooth problem
Note: This is for a 550c Street pilot
1) Turn on unit
2) Press VIEW MAP
3) Press SPEED in lower left hand side of map
4) This will bring you to the Trip meter screen on this screen press the round speedometer at the top of the screen for about 10 seconds this will bring you to the SYSTEM BIOS.
5) From this point forward be careful you can mess up your unit by changing the wrong thing.
6) Press NEXT until you come to the BLUETOOTH STATUS screen.
7) Now press UPDT P this should complete your update.
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth enable
The complete solution - user reset is NOT necessary:
Whenever I purchase a new electronic device, the first thing I do is update the firmware. This has me in a bind in this case.
I updated my Nuvi firmware, then my BT firmware.
A few days later, I got the "Enabling Bluetooth" hang. I followed the advice on this page, but "Bluetooth Firmware Update" would not appear in the webupdate list.
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
296 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
