Question about Dryers
What buttons do i press for the diagnostic test i forgot how to do it
  • 530 Answers
What is your model number?
usually it is more time and less time and toggle these keys within 6 seconds until all the lights light up.
Posted on Aug 28, 2010
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
Tip
Self Diagnostic test
Having troubles with your Axim x51V?
You can allow the device to perform a self diagnostic test that will make it run a series of tests (CPU test, LCD test, RAM test, Interactive Button test, Sound and Recording test, Touch Panel test)
To enter the diagnostic area, Press and hold POWER and RECORD while pressing the reset button on the back. Continue to hold the POWER and RECORD buttons while releasing the reset button and wait for the screen to show the diagnostic window. Select the envelope icon button to begin the test or press calendar icon to exit and reboot without testing.
on Mar 14, 2008 | Dell Axim X51v Pocket PC
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have changed the radiator, heater core and the thermostat in my 1997 ford F150 but I am still blowing out cold air
THE TEMPERATURE BLEND DOOR STUCK OR BLEND DOOR ACTUATOR MOTOR FAULTY,YOU NEED TO DO A EATC DIAGNOSTIC TEST TO GET FAULT CODE SEE WHY YOU ARE NOT GETTING HEAT.TO DO A DIAGNOSTIC TEST FIRST WARM ENGINE UNTIL IT GET 120 DEGREES.WITH ENGINE OFF IGNITION SWITCH ON SIMULTANEOUSLY PRESS OFF AND FLOOR BUTTON THEN WITHIN 2 SECONDS PRESS AUTOMATIC BUTTON SELF TEST TAKE UP 20 SECONDS INDICATING BY BLANK DISPLAY WINDOW ON THE EATC MODULE. IF DISPLAY IS BLANK FOR MORE THAN 20 SECONDS OR IF CODE 888 IS DISPLAYED GO TO EATC SYSTEM TEST UNDER TESTING IF NO CODES ARE DISPLAYED AND SYSTEM IS NOT OPERATING PROPERLY GO TO SYMPTOM DIAGNOSIS IF CODES DISPLAY RECORD CODES. BEFORE TURNING IGNITION OFF EXIT SELF DIAGNOSTIC.BY PRESSING DEFROST BUTTON EXIT THE SELF DIAGNOSTIC PRESS BLUE BUTTON. IF ALL FAIL LET A GARAGE CHECK IT OUT.BUT ALSO CHECK COOLANT SYSTEM IF COOLANT SYSTEM VERY LOW YOU HAVE NO HEAT PROBLEMS.
Oct 19, 2011 | 1997 Ford F150 Regular Cab
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
My Escape Radio, CD, and Aux input will not work. My temp gauge works, but all music controls do not, except for the load and eject buttons for the CD player. I replaced three fuses that according to my...
Which three fuse's did you replace ? You should check for B+ voltage on both side's of the fuse . Two little metal tabs on top of the fuse. Voltage on both , fuse is good .
Try radio self-diagnostic mode .
A fluctuating AC voltage audio signal is sent to the speakers directly from the audio unit to reproduce sound. The audio unit has a self-diagnostic mode that can be entered by pressing preset buttons 3 and 6 simultaneously.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna or antenna cable
  • Speaker mounting/speaker cones
  • Radio ignition interference capacitor, radio frequency interference suppression bond, or radio receiver hood bonding strap
  • Smart junction box (SJB) fuse(s):
    • 7 (10A)
    • 12 (5A)
    • 16 (15A)
  • Battery junction box (BJB) fuse(s):
    • 7 (40A)
    • 15 (20A) (Hybrid)
    • 16 (25A)
    • 21 (40A)
    • 22 (40A) (Hybrid)
    • 23 (40A) (Hybrid)
  • Subwoofer amplifier
  • Circuitry
  • Audio unit
  1. If the concern is visually evident, GO to Symptom Chart .
  1. If the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
Speaker Walk-Around Test (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in the radio tuner mode (AM/FM).
  1. To enter the speaker walk-around test, simultaneously press the audio unit preset buttons 3 and 6.
  1. The speaker walk-around test stops at each speaker and applies sound to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR and SUBWOOFER.
  1. To exit the speaker walk-around test, turn the ignition switch off, turn the audio unit off, or press preset button 1 for diagnostics (DIA).
Audio Unit Self-Diagnostic Mode (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has 6 manual tests available:
    • Preset button 1 = ENTER DIAGNOSTICS. This test enters diagnostics from the speaker walk-around test. Metrics are available with SEL and ON buttons indicating time played in AM/FM, media, number of buttons pressed, etc.
    • Preset button 2 = EEPROM BLOCK STATUS. This test shows the validity of memory to calibrate the clock, and seek sensitivity.
    • Preset button 3 = EXIT DIAGNOSTICS.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for its software configuration level.
    • Preset button 5 = DISPLAY TEST. This test lights all the display segments for five seconds and then turns all segments off.
    • Preset button 6 = RAM CONTENTS READOUT. To enter these tests, press preset button 1 while in the speaker walk-around test, then the desired preset button.
  1. To exit the self-diagnostic mode, turn the audio unit or the ignition switch off.
Oct 06, 2017 | 2008 Ford Escape
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Stereo not working, and slidind doors either. need fuse diagram
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
May 25, 2009 | 2002 Ford Windstar Cargo
Dryers Logo
48 people viewed this question
Top Dryers Experts
