Question about Frigidaire Electric Dryer
The dryer turn on but no heat and the screen code is AD.
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 28, 2010
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
Ad error code
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Error code Ad
Hello Rachael, thank you for your inquiry!
Typically error code AD indicates that the Auto Dry option has been selected. Typically when using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting another option or resetting your dryer. You may either unplug it or flip the household breaker off for approximately ten minutes. Turn your dryer on then select a normal cycle. Your appliance should resume normal operations. If this problem persists, your dryer may possibly have a faulty heating element, blower assembly or a communication problem with the control panel. This is not a normal DIY job. You may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
Nov 28, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer error code AD
Hello - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Jan 07, 2013 | Frigidaire AEQ6000ES Electric Dryer
No heat
Hello Patty Hanna - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Oct 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire dryer isn't heating up..and after 20min.. is displaying AD??
Is this the only code you are showing...The AD indicates the dryer is in the Auto Dry cycle....You most likely have a blow thermal fuse...A faulty heater coil...You would need to break dryer down and test components with a meter.
Here is a tech sheet you can download...This will walk you thru the troubleshooting.
http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf">http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf
Mar 11, 2012 | Frigidaire Dryers
Displayed codes
Error code "AD" means air/automatic dry. This type of dryer has no thermo fuse which is a fuse like part that tends to break disengaging the heating element, there for the dryer has a busted heating element.There is no other go you should go for a replacement of your heating element. This solution will solve your problem.
Apr 18, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLEQ2152ESO Dryer flashing AD
AD means "auto dry", which means the dryer is supposed to be detecting the moisture levels in your clothing and adjusting the drying time accordingly.
If your dryer is flashing "AD" and turning off shortly after the start, there is likely a problem with the mechanism designed to detecting the moisture levels. If it turns off after trying to use all various settings (including the no-heat feature), it is likely a wiring issue.
Mar 27, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Error code on dryer display
Check your breakers. Mine was doing the same thing, all of the 120v parts of the machine were working. (blower/drum motor/ lights) However the element wasn't coming on. Went to the breaker and found that one side of the 2 pole breaker was tripped. Turned both off and back on. Heater started working again.
When you set the dryer on settings such as normal or permanent press, it engages the various sensors that help the dryer to make the most efficient use of energy. Moisture sensor, heat sensor etc. (THAT IS WHAT TURNS ON YOUR AD SETTING) Normally it selects a time based on factory settings that it believes your load should be dried by. Say 50 minutes at Normal (high heat, normal) Every so often during the cycle, the machine will check the humidity sensor and the other sensors and try to see if the dryer is still on schedule. Sometimes it will determine that more time is needed, occasionally less time. While it calculates, it displays the Ad meaning that the machine is on auto dry. TO TURN OFF AUTO DRY, set it to a time setting instead of a DESCRIPTION setting.
Oct 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
80 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
