Question about Dishwashers
Broken locking plastic clip on the door, that shoots the door to start the washer, and that opens the door when finish
  • Dishwashers Master
  • 43,501 Answers
That part is not that hard to fix and you can easily buy a new one online...replacement instructions usually come right with the part also...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 28, 2010
2012 chry 300c driv door cent lock will not open fully causing door not to open, other doors are Ok. Lock goes up/down but the lock only comes up half way,unable to open with key and from inside
They use plastic clips to secure the rods that lock and unlock doors. Sounds like the clips are broken or the rods(metal) need adjusted/ bent..
Nov 30, 2015 | Cars & Trucks
Sliding door handle will open from inside but not the outside
the outside door handle connects to the lock by a metal bar and 2 plastic clips. One of your clips have broken. You can get the clips at any auto parts store. very easy to replace. just remove the door panel, and you will see the clips at the lock and handle. every thing just slips on and snaps in. hope this helps
Jan 13, 2011 | 2005 Chevrolet Express
When washer starts it usually makes a clicking noise know it is humming and nothing happens the door is locked and wont open
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Aug 23, 2010 | General Electric WCVH6800J Front Load...
Washer locked. door lock light blinking. start button light on. won't do anything.
IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The lock on my front driver door will not unlock with power locks the rest the door will not even open when i attempt to open from the inside i tried unlocking it with the key but it made a sounds like...
You will need to remove the inside door trim panel and check the three (3) rods and plastic connectors that connect:
(a) the inside door handle to the door mechanism
(b) the inside door lock knob/outside key lock cylinder to the door mechanism
(c) the outside door handle to door mechanism.
Most likely one (or more) of these rods have either become loose or the plastic lock clips have broken.
The "L" end of the rod goes thru the hole of the clip and the clip has a pivoting "U" shape that goes over and locks onto the rod.
Based on the your year (2000) it might be a good idea to remove all clips and rods; and remove the entire door mechanism. Inspect, clean, lubricate, and re-install it.
Dec 28, 2009 | 2000 Ford Expedition
Searching for a clip
Iwould asssume your lookin for number 32 on the door nd latch breakdown, you can call hyour local part distributer for ordering info
#32 8181929 Clip, Trim
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180440.pdf
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
2003 chevy impala broken handle
raise the window.
remove door pannel and water shield.
remove the plastic clips that secures the lock cylinder to the latch rod.
slide the lock cylinder clip out of engagement and remove lock cylinder from the door
disengage the plastic clip that secures the outside handle to latch rod.
remove bolts
then pull it out of door
Nov 23, 2008 | 2003 Chevrolet Impala
Door does not open
If you have the barn-style rear doors the lock mechanism has small plastic clips inside that basically join the handle to the metal rod that opens the latch. You have to take off the inner trim panels and then peel back the plastic liner and you can see if one of them is broken. Most auto parts stores have the clips in stock for around $3.
Jul 03, 2008 | 1995 Chevrolet Tahoe
Washer won't start; has alternating "dl" and "f" errors....can't reset
This is a Door Lock Error. The service manual lists the following causes: Door Lock Mechanism is broken or removed from door. Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this). To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Oct 28, 2006 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
