Question about Palm Treo 650 Handheld
Casing crack My phone has nbeen dropped and the face around the screen cracked. it wasn't the screen, just the blue plastic surrounding it. Can I replace this without replacing the whole casing? It is a cingular phone if that matters. Thank you.
    Sergeant:
  • 234 Answers
Change the mobile panel and put cover to the mobile! if display have cracks mean buy display stickers and paste it to the display! just try it
Posted on Jun 30, 2008
How can i fix my cracked phone screen
Got Cracked Screen 5 Best Smartphone Screen Repair Options
Over time, this can affect the device's functionality and usability. (Also, a cracked screen just doesn't look that good.) Until you can get it fixed, put a plastic screencover on your phone. Then look around for the best way to solve the problem permanently. Click on link above more detail ........
Oct 25, 2016 | Cell Phones
Where can get replacement plastic cracked around blade on ultimate chopper where can get replacement
talk to an appliance service center to see if they are available
go google to the manufacturer's spares department
Sep 14, 2015 | Ultimate Chopper Food Processors
My son said he spilled soda on his dsi... it didnt get that wet but i think he dropped it. The bottom screen is a little faded and has lines in it. it still plays. is there a way to fix the lines?
No there is really no way to fix it unless if you ask the creator of of the dsi because the drop sorta cracked the screen of it. Depending on the side, top, bottom, back, where ever, it still cracks not necessarily crack but it has been to the point when it can't be fixed. The same problem happen to me except the case was that I dropped it a little more harder and the screen totally went black.
Mar 04, 2013 | Nintendo DSi Matte Blue Console
Cracked screen
If the plastic cover is cracked but the LCD is fine, the fix is very different. In some ways it's actually harder than replacing the LCD, which is simply connected by a ribbon cable. One challenge for you is that, unlike the LCD, which is available as a replacement part (on Ebay - about $25), there is no direct replacement available for the plastic covering. You will need to pick up another 880 that is being sold for parts and then salvage the plastic screen from there. I'm not sure I can actually describe the replacement procedure to you without pictures but here is the general idea:
First, you need to open the remote so that you can work with the top half. To open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the ****-shell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Now, take the bottom of the remote that is holding the logic board and put it aside. You will only need to work on the top half of the ****-shell case. Ok, now looking at the face, there are 4 pieces of silver trim that are locking the plastic screen into the case, two on each side; the piece directly above the Mute button and the Prev button (they look like unmarked softkey buttons), and the two thin elongated pieces at the top on either side. To remove these pieces, you need to turn the top half of the casing over so that you are looking at the underneath at the area of these 4 trim pieces. If you look carefully, you can see that there are very tiny posts covered with glue that are holding in these pieces. You need to forcefully, but carefully scrape the glue off and try to push the trim pieces out from the back. Try to do this is carefully as possible, since the surrounding plastic is delicate. Once you pop these pieces off, turn the top half back right-side up. Now the only thing holding the screen down is a kind of rubber cement around the perimeter. To remove your cracked screen, you can pull it off from the bottom without worrying too much. However, be very careful when trying to get your replacement screen off of the salvage remote! The screen must be pried up gently and slowly from the bottom. If you use too much force, you risk cracking the screen as you pry it up. If you wind up scraping some of the black paint on the screen's perimeter, you can use a permenent marker to color it. Back on your good remote, remove as much of the cement as you can and lay down some double-stick tape (a glue stick may work also) and lay the new screen down so it is aligned perfectly in the space. Then attach the trim pieces and use some epoxy on the underside to affix them in place. Re-assemble your remote and it should be as good as new. Good Luck!
Sep 06, 2009 | Logitech Harmony 880 LCD Remote Control
The top case surround the screen has cracked on both sides of the latch and cracked on one corner. No rough treatment.
So what are you asking?
Sounds like you need to replace the top of the case. I have no idea why it cracked--you said there was no rough treatment (by you?)
Could someone else have messed with it?
It could possibly be a factory defect. If your machine is under warranty, that would qualify for replacement of the plastic. Otherwise, you're going to have to either glue it or buy a replacement bezel.
Jul 08, 2009 | Panasonic Toughbook 52 - Core 2 Duo P8600...
Unable to remove screen surround on Acer Aspire 6930
Walk into a Computer hardware shop. Of course they will have all the required tool to open the laptop up and fix the new screen.
Mar 17, 2009 | Acer Aspire 6930-6771 Laptop
Cracked case
Hi there.
You can order spare parts from Acer themselves or alternatively look on Ebay for spare plastics.
It sounds like you need the lid face and bezel (plastic that surrounds the screen), as for disassembley i'm afraid its trial and error as you may have to take the laptop apart to replace the plastics.
Good luck and thanks for using FixYa!!
Mar 04, 2009 | Acer Aspire 3680 Notebook
Hi I Have a plasma 42inch bravio and we dropped the plasma when we were moving, now its cracked, but it still goes and everything, I was wondering can it be repaired or fixed
Is the screen cracked? If it's just the black plastic surround you should be able to get a replacement, but being Sony it would probably be cheaper to replace the TV. You could probably get it repaired under insurance if you are insured.
Apr 06, 2008 | Computers & Internet
Replace razor screen / cover
yes, but you need the rigth tools, google v3 razr repair. just buy new razr housing on ebay. it'll look like new
Oct 24, 2007 | Motorola Mobility RAZR V3
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
