Question about Arris SURFboard SB5101 Cable Modem
Modem can't see ethernet card - Arris SURFboard SB5101 Cable Modem
    Novelist:
  • 142 Answers
I'm sure you have tried most of these steps but I'm going to list them any way so we have a complete picture of the trouble shooting process.
First you will want to power cycle the computer and modem, To do this you will need to shout down the computer and disconnect the power cable from the modem . Allow all devices to remain off for 2 minutes. Plug the modem in first. Wait for the modem to establish a connection with the internet service provider(ISP). Depending on the type of modem this can take up to 5 minutes. Then turn on the computers in the home. Next try replacing the Ethernet cable. If still there is no connection from the modem to the router then try another computer. Before you can connect another computer you must power cycle the modem again. If the second PC has the same issue than your modem will need to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Posted on Sep 01, 2010
I have no usb cable
Most routers dont use USB, they use ethernet. Ethernet will require an ethernet adapter installed on your computer, this is also known as a Network interface card. Depending on if you have a modem or not, you run the ethernet cable from the modem to the routers internet/modem/wan port, then another ethernet cable from the router to the computer.
Feb 05, 2011 | Computers & Internet
I have netgear wireless N-300 router. Linksys cable modem. Arius phone modem ( comcast trip play). Netgear not reconizing ethernet connection. My connection is yellow ethernet cable to linksys, grey...
If you mean phone modem on PC then no. Check connection between pc and router by acessing the webinterface (instuctions in linksys user manual).
If all OK there then contact your ISP.
Sep 03, 2010 | Computers & Internet
The PC/ACTIVITY my Motorola modem isn't on... i don't know what to do.
if all of the other lights on the modem are lit, except pc activity, that means the modem isnt communicating with the computer. 3 things can cause this - modem could be bad, ethernet cord could be bad, or the NIC card(the card in the cpu that houses the ethernet port) is bad. Most of the time its the ethernet cord or the NIC card in my experience. Dont fret, both of those are relatively cheap fixes.
Apr 04, 2010 | Arris SURFboard® SB5101 Cable Modem
Can't plug ethernet cable from modem into dell
You will need to get a PCI ethernet card and install it.
Your computer doesn't have an ethernet connection on the motherboard.
Nov 23, 2009 | Dell Computers & Internet
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
I had a lightning strike now my RZ26G wont connect to the internet. Verizon said to get a new ethernet card....i dont see one --- help how can i get back on the internet?
The ethernet card is embedded in the motherboard on this model,If you have a vacant slot on the motherboard you can install a new one there.any brand should do.
Good luck
Oct 22, 2009 | Sony VAIO Digital Studio PCV-RZ26G PC...
Ethernet cable does not fit
The modem jack is too small because it is for a phone line connection not an ethernet connection. If you want to get online by dial-up, you need to connect modem to a phone line. Ohterwise look for another input jack on the laptop that the ethernet cable will insert to.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 10, 2008 | Dell Latitude CP 56K PCMCIA Modem Card (PC...
Network card
Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
Nov 12, 2008 | IBM ThinkPad A21m 2628 Notebook
Ethernet Card
Do a ipconfig at the command prompt and see if you are being assigned a ip from the modem. If not try rebooting the modem with the ethernet connected to modem and computer. then do ipconfig again to see if not getting internet ip, your card or modem eternet is bad. put in a new one and try again.
Jun 01, 2008 | HP PAVILION A6230N DESKTOP PC
My Mdoem's ethernet and usb lights are off
assuming you using ethernet to connect the pc to the modem: how about checking your ethernetLAN card on the pc if it's integrated with the motherboard you can enable it from the bios settings if it's an expansion card it sounds like you need the most up to date driver which can be downloaded from the card manufacturer's website if you have access to internet on another pc. assuming your pc is connected to the modem via usb: reinstall the driver for the modem . another thing you can do is buy a usb to ethernet adapter which are available for under $5 on the market one end connects to the usb port on your pc and the other end is ethernet and this should work .
Aug 10, 2007 | NetGear DM602 ADSL-Modem
Arris SURFboard SB5101 Cable Modem  Logo
74 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
