Question about Motorola Mobility Q9m Smartphone
My battery dies every day and when I plug my phone in it still says low battery
  • 4,102 Answers
Hi, this is a very common problem with all smart phones they use so much of their battery that the battery life drops really quick the only option you have is to get the battery replaced this will then solve your problem for a while but its not going to last forever, if you go to your nearest phone shop ask them if they have got an heavy duty batteries for your phone, they do make them but are hard to come buy.
one other thing to remember is this, once a month let the battery go totally flat let it go so flat that the phone wont even light up when you press the on button, now do a full charge over night doing this keeps the battery at its best and prevent any bad cells forming so if you do this say once a month or every 6 weeks it will prolong the life of the battery by load so bare this in mind when you get a new battery.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 28, 2010
PC - dies no power, but comes to life after a few days if left unplugged. Then it works and at somepoint dies again (no fans, power, etc) How do I fix?
My first thought would be that it is a power supply problem. But, before replacing the power supply, unplug the power cord from computer and wall plug, plug it in a gain making sure it goes in all the way.
If still flaky, its probably a power supply problem.
Hope it helps.
Jan 20, 2015 | HP Pavilion 725n PC Desktop
Solutions c414r can't turn on only charges
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 08, 2012 | Cell Phones
The batterie in my phone must be so low I can't get it to charge. Does this mean I have to buy a new one.
Please check your charger for malfunction first before decide to buy new battery.
Jan 29, 2011 | Cell Phones
My Lg Xenon is not charging properly. It says full battery after i charge it but then when i talk to someone on the phone after about 20 mins it starts beeping saying it has low battery and eventually...
I had a similar problem with a brand new LG Xenon. The battery charger said it was charging but the phone didn't charge. When the battery life on the phone died the phone would not turn on with the charger. I plugged it into my USB port on my laptop and the phone fully charged for real. I got 4 days before I had to recharge it again. Try USB cable to a PC to charge phone. Charger is probably bad. I am getting a replacement and will see if that works.
Oct 21, 2010 | LG Xenon GR500 Cell Phone
My phone died and now it won't turn on. When I plug it up it tells me low battery and nothing...
Change your phone battery, buy a new one because your battery is busted and cannot be used again..
Oct 24, 2009 | Motorola Mobility Boost Mobile...
My garmin 305 dies when power is applied to charge or download
item returned to garmin europe after a phone call and diagnosis
Aug 01, 2009 | Garmin Forerunner 305 GPS Receiver
GE cordless phone showing low battery (model 27958GE2-A)
Your phone may have a faulty sensor. If the only notification is that your screen displays low battery, and there is no interruption or disruption of service or quality to the product you can most likely leave it as is. If your phone is still under factory warranty, do not replace the battery, ask for a replacement for a faulty product. I would personally test the lifetime of your phone by leaving it off the charger for a day, and if it lasts the entire day without dying, then it is a problem with your phone's sensor / battery indicator. If the phone dies after a few hours of use or standby, then there is a problem with your battery and your battery tester.
Jun 15, 2009 | Uniden Cordless Phone
Battery dies really fast
Since it's a new phone, I would suggest checking the outlet the charger is plugged into. The outlet may not actually be charger your phone. If you try another one and the battery still drains quick, I'd definately see if I could return it.
Apr 02, 2009 | LG Vu CU920 Cellular Phone
Phone dies quickly after charging
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but... Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever). Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies. If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current. This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different. Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities. A.
Jul 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility Q9m Smartphone Logo
91 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
