Question about Daewoo Heating & Cooling
Ac compressor will not run (kicks breaker) - Daewoo Heating & Cooling
    President:
  • 3,074 Answers
Check wire to make sure they are not burnt on the compressor, if they are not then check to see if compressor is shorted.
Posted on Aug 28, 2010
Model 160 c when AC goes on after about 5 minutes causes the circut breaker to go. The fan does not do that when it is turned on, only the AC. THANKS JEFF
Hi Jeff,
The compressor is either locked up or shorted....
The five minute delay is built in to keep the compressor from starting under load..
Then when it kicks on the high amp draw will kick the breaker...
In most cases the cost for parts and labor to replace a small compressor are more then the unit is worth...
The best thing to do is to replace the whole unit.
heatman101
Jul 03, 2011 | Hampton Bay Heating & Cooling
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Keeps kicking breaker
Your unit is pulling too much power which is popping the circuit breaker. Either the compressor motor or Fan motor has a problem and you need a pro here. Drawing excessive electrical current is not good and you can do even more damage to your unit by continuing to try and run it!
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
I have a coleman model 8333A8664 a/c unit on a fleetwood camp trailer and was wondering what watt generator would be needed to run it properly?
Because it won't be powering just your AC, I would recommend 5000W. It's that big amp draw when compressor kicks in that will pull it way down, if not strong enough. Take for example the fact that a dedicated 20 amp breaker and cable are the norm for RV's to use for AC now. Double check also that the generator your purchasing will take a momentary surge draw of up to 20+ amps without tripping breaker on generator. I say 20+ because once RV is plugged in or wired to generator, it will be powering any other hydro operated appliances, lights, converter etc that the trailer has on board. I bought a cheapie rated at 4000W, and 3000 running watts, but it kicks out the breaker just trying to start my portable air compressor, rated at 15 amps.
Jun 10, 2010 | Heating & Cooling
My RC air conditioner (Duotherm) kicks the circuit breaker every time I turn it on. It used to kick the circuit breaker every so often, but lately it kicks it immediately if I try to turn on the AC.
Try replaceing the start or run capacitor to the compressor. If no help you can install a start assist capacitor, it helps to start a tight compressor.
Sep 10, 2009 | Dometic Rooftop RV Air Conditioner
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
AC wont kick on....
The first thing to check is your breaker box. There should be one double breaker for the air handler unit, that's the inside unit, and one double breaker for the compressor, that's the outside unit. Check both breakers. If you're not sure if they've be thrown, click them toward the outside of the breaker box (off position) and then click them toward the inside of the breaker box (on position). If the breakers are on and you still are not getting any A/C take a look at your compressor, (outside unit). If the fan is running at least you're getting power. However, your compressor down inside the unit may not be getting power or it may need to be replaced. The compressor has a start-up cap. If this cap goes bad or the wires from this cap fry or corrode away, this will also keep the compressor from starting but the fan will still run. If the fan is not running it could be caused by a faulty relay inside the compressor cabinet. This relay is supposed to open and close based on a low voltage signal from the thermostat. I believe it's roughly 24 volts. This relay switches on and off the 240 volts for the compressor and the compressor fan. Often this relay goes bad or the wires leading up to it fry. If you?re going to work on the unit yourself make sure all power is shut off. There should be a shutoff switch on the outside wall near the compressor. I?d also shut the breakers off.
Jun 12, 2009 | Honeywell Programmable Thermostat Heater
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
May 10, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
